seemingly random missing - JeepForum.com
post #1 of 1 Old 06-20-2011, 09:29 PM Thread Starter
hogman500
overview
so a brief overview of what is happening is that I did an engine swap because the engine i had was making strange scary noises and it was just as much to replace with a used motor as it would be to rebuild so anyway the motor is a 1983 motor recently rebuilt with about 45000 miles on it which is much less then the motor i took out which had 166000 miles on it. in addition the new motor has headers and had an upgraded ignition which i removed and put the stock ignition back on hoping it would fix the problem.
issue
so the misses are seemingly random although i know its electrical in nature because the gauge spikes and dips every time it misses. a while back i traces the problem with an oscilloscope to the pick-ups on the distributor which i swapped out along with the vacuum advance solenoid. then for about a week it ran perfect then randomly a week later it was back to how it was missing low idle dyeing in turn lanes you know what i mean. its gotten so bad we had to borrow a vehicle and not drive the Jeep. and the miss is not consistent its not once a revolution or within any particular period it just happens and it sputters and dies.
what ive already tried
i am putting this because these are the things everyone always tells me and ive been through it tons of times already.
  1. check and replace spark plugs
  2. replaced pick ups with good ones
  3. checked timing
  4. checked plug wires and replaced with known good ones
  5. ruled out valves because they just had a 3-point valve job
  6. ruled out piston rings because of recent rebuild
  7. many other basic things including having a mechanic look at it which dident help at all
  8. replaced a special vacuum part which made a huge improvement on kicking up the idle when cold
this is becoming a serious issue
this vehicle is supposed to be a daily driver if this keeps up without us finding a fix we may either have to put the old motor back or sell it.
thanks in advance for any help and all advice will be helpful
hogman500 is offline
engine swap , ignition , miss , random , wiring
Random loss of 12v to accessories Sneakboxer Audio, CB & Ham Radios, GPS, & Electrical 3 10-17-2009 09:52 PM
factory cd player on random? bradknapp Audio, CB & Ham Radios, GPS, & Electrical 5 03-17-2008 09:21 PM
random non start RebelYJ Engines & Drivetrain 1 10-11-2007 01:48 AM
a few random questions. mdsuave13 General Jeep & Off-Road Equipment 0 09-22-2007 09:10 PM
91 I6 random smoke (91 w 200k) dirkdiggler106 Engines & Drivetrain 4 10-14-2006 01:11 PM
