Sealing up 4.0 timing cover - JeepForum.com
post #1 of 2 Old 10-28-2013, 08:56 AM Thread Starter
CharlieHo
I just had my cover off a month ago. Found two of the four bolts that come through the oilpan stripped. Helicoiled those and tried to RTV the existing rubber gasket back into place upon reassembly.
This weekend I found it still leaks
I only get leakage on steep descents, but, if oil can get out, water can get in.
Any tricks to get this sealed back up without dropping the pan? RTV the heck out of it?
I may have to drop the pan, but, I don't want to aggravate an otherwise non-leaky engine. You know how it is, it doesn't leak until you mess with it.
Originally Posted by mdm
You could ask it nicely to move over. When that doesn't work, get a bar or 2x4 and ask it again.
I have the ability to spell correctly, it's just that the autocorrect on my iPad will not permit it.
CharlieHo is offline
post #2 of 2 Old 10-28-2013, 02:46 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Probably best to drop the pan and use the one-piece felpro gasket.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
