Sealing off unneeded ports on aftermarket replacement exhaust manifold? - JeepForum.com
post #1 of 8 Old 09-02-2011, 01:09 AM Thread Starter
NonRubicon
I just got a replacement cast iron exhaust manifold and it is made to fit several different years of the 4.2L, so it has ports that aren't on the 1990. It came with threaded steel plugs to block off any ports that I don't need.
Do I need to do anything other than get the plugs good and tight to make sure they don't leak? I'm guessing that JB weld or red loctite wont withstand the exhaust maifold temps.
this is the manifold:
NonRubicon is offline
post #2 of 8 Old 09-02-2011, 07:03 PM Thread Starter
NonRubicon
Just thinking...anyone use 2000*F copper RTV for sealing plug threads on the exhaust manifold smog ports? Or should I just find some NPT brass fittings and not bother with RTV to seal the threads?
post #3 of 8 Old 09-02-2011, 10:14 PM
JHW12084
1990 XJ Cherokee
just use teflon tape.....thats what i always used
JHW12084 is offline
post #4 of 8 Old 09-03-2011, 12:03 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Let's see, I've been using brass hardware on the exhaust system for the last thirty years or so, and putting RTV Copper on exhaust gaskets as a matter of course for at least twenty - and having no trouble either way. So, you'll be fine.
Theoretically, NPT doesn't require the use of sealant - but I know I feel better if I use the stuff anyhow. RTV Copper - I've not quite worked myself up to using PTFE on anything that runs over 500*F, no matter what the label sez...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 8 Old 09-03-2011, 12:35 AM Thread Starter
NonRubicon
Thanks for the replies.
Not really sure about teflon tape withstanding exhaust manifold temps myself. I'll check around the local hardware stores and see what NPT brass fittings I can find.
post #6 of 8 Old 09-05-2011, 08:34 PM
1986cj
Just put the plugs inplace of the Air Injection Manifold Pipe, They are not going to leak and after they have been in for a while you will have trouble getting them out.
1986cj is offline
post #7 of 8 Old 09-05-2011, 09:00 PM Thread Starter
NonRubicon
Ended up just using the plugs that came with the manifold. Brass fittings were too expensive. Put a little copper RTV on them to help ensure the threads are sealed good for now. Kinda figured that they would eventually get frozen in, but wasn't to sure about them leaking any when newly installed.
Thanks again all.
post #8 of 8 Old 09-28-2011, 09:15 PM
imac61
1980 CJ7
just use some teflon tape
imac61 is offline
TJ exhaust manifold Steves04jeep Engines & Drivetrain 3 08-01-2011 02:52 PM
Exhaust manifold PH1L Engines & Drivetrain 1 10-05-2009 12:20 PM
What style exhaust ports are these??? atomicjoe23 Engines & Drivetrain 2 08-27-2009 12:39 AM
94' 2.5L exhaust manifold gasket replacement JayBanion Engines & Drivetrain 4 10-12-2007 08:45 PM
exhaust manifold TJAggie2002 Engines & Drivetrain 3 09-11-2003 06:04 AM
