-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   Sealing diff cover (http://www.jeepforum.com/forum/f19/sealing-diff-cover-1565284/)
hub0619 08-21-2013 12:20 PM
Sealing diff cover
If I used to much silicon sealant could it be a problem? Like could it get in the gears or something? Just wondering if to much can be a big problem
biffgnar 08-21-2013 01:45 PM
22 Attachment(s)
What do you think dried RTV would do to hardened gears?
uberxj92 08-21-2013 08:51 PM
Its not the gears that would worry me. Its the clutch packs
Holder350 08-21-2013 09:15 PM
Shouldn't be a problem. Even for the clutch packs, pieces big enough to do any kind of harm won't fit between them.
Its rare that RTV breaks loose on the inside of the case anyhow. It usually oozes into the case and hardens and sticks there.
Sent from my phone
Evildriver-3 08-22-2013 05:59 AM
The gears and clutch won't be a problem, but the front bearing being starved from having its oil blocked will.
You're putting a cover to a machined surface it needs less than 1/4 wide bead and its sealed, or just use the gasket and no silicone
The time now is 02:38 PM.
