SBC 350 Timing Question - JeepForum.com
post #1 of 6 Old 07-23-2007, 07:22 AM Thread Starter
cconn
Mud Bogger
cconn's Avatar
I recently installed a new SBC 350 and am needing to set the time today. I have an adjustable timing light but can't remember what a SBC should be set at. The 1970 440 Charger I last worked on ran great set at 32*. Anyone suggest a good starting place for the timeing?
2013 Commando Sport. Rock Krawler 2.5" X-Factor lift. 35" MT/R's, 17x9 Pacer black wheels. ProRock 44 front axle. RCV shafts, ARB front and rear lockers. 4.56 gears. Coast 1310 drive shafts. TeraFlex adjustable tire carrier. AEV front bumper. Warn 9.5 CTI winch. TrekArmor seat covers, Spiderweb shade
Build Thread :
cconn is offline
post #2 of 6 Old 07-23-2007, 10:08 AM
mike06X
are you running a vacuum advance distributor? i run my sbc's with mechanical advance only and i have advance all in around 2800 with light to medium advance springs, which is also the stall speed on my converter (i always try to match converter stall speed, when mechanical advance comes in, and cam power-range - this makes for nice performance); and i run total advance 32-34 degrees, and i run the most base advance i can run and have the engine start easy..depending on how old the engine is and what condition its in, set it for 30 degrees total advance and listen for pinging and check the plugs, then go up to 32, or 34, whatever it will run without pinging, knocking, or over-heating the plugs..run r-43's or r-42's and a 180 t-stat and you should be able to get 34 degrees total out of it safely.
i am also not concerned or accounting for emissions or fuel economy with my applications.
84 CJ7 - AMC360 & T727 | 35 BFG-KM2
mike06X is offline
post #3 of 6 Old 07-23-2007, 10:48 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
need to know the year of the motor...
carb, tbi or tpi.
tbi, all you can do is set the base timing, the ecm will do everything else for ye, so not a lot to do there....tpi is the same IIRC.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #4 of 6 Old 07-23-2007, 12:46 PM Thread Starter
cconn
Mud Bogger
cconn's Avatar
Not sure of exact model. 80-something i believe. Carb with vacuum advance.
Build Thread :
cconn is offline
post #5 of 6 Old 07-23-2007, 07:34 PM
1 ton yj
1 ton yj's Avatar
Set the base at 8-10 degrees and make sure the total advance doesnt go over 35 or so.
go peel out!
1 ton yj is offline
post #6 of 6 Old 07-23-2007, 07:37 PM Thread Starter
cconn
Mud Bogger
cconn's Avatar
Thats kinda what I was thinking but its been a few years since I worked on a bowtie. Thanks for the replies.
Build Thread :
cconn is offline
88 Cherokee Timing Question F1504x2 Engines & Drivetrain 0 08-11-2008 05:37 AM
timing question, is this right? RedJeepXJ Engines & Drivetrain 1 09-12-2003 09:28 PM
Timing Question? mde Engines & Drivetrain 1 11-19-2002 12:42 PM
ignition timing question CJ8DV8 Engines & Drivetrain 8 04-06-2002 05:14 AM
Timing Chain Question holmes133 Engines & Drivetrain 0 02-22-2002 10:23 PM
