SBC 350 help - JeepForum.com
post #1 of 4 Old 07-05-2013, 09:18 PM Thread Starter
fang_x
SBC 350 help
I just picked myself up a new car,
It was running fine untill i heard a click, apon prodding around I discovered that its caused by one of the rocker arms, the bolt that's in the head is working its way out, which caused one of the rocker arms to wear. Any idea how to get that bolt back down?
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #2 of 4 Old 07-06-2013, 05:11 AM
Newtons3
If its factory, its a press-in stud. You will need to pull it, drill and tap the hole for screw-in studs. You REALLY should do all of them. I strongly recommend pulling the heads to do this. If you already have screw-in studs, just install 2 regular nuts, tighten then together, and use the top one to screw the stud down.
Newtons3 is offline
post #3 of 4 Old 07-07-2013, 04:35 PM
carpslayer
Same as what newton said but I would check that valve out to make sure its not bent.
carpslayer is offline
post #4 of 4 Old 07-07-2013, 05:51 PM
Newtons3
I agree, further reason to pull the heads. What kind of spring pressures are you running?
Newtons3 is offline
