-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   SBC 350 help (http://www.jeepforum.com/forum/f19/sbc-350-help-1545474/)
fang_x 07-05-2013 09:18 PM
SBC 350 help
I just picked myself up a new car, http://i148.photobucket.com/albums/s...ps0f0a44d6.jpg
It was running fine untill i heard a click, apon prodding around I discovered that its caused by one of the rocker arms, the bolt that's in the head is working its way out, which caused one of the rocker arms to wear. Any idea how to get that bolt back down?
http://i148.photobucket.com/albums/s...ps0d33388f.jpghttp://i148.photobucket.com/albums/s...ps0b3cb9fd.jpghttp://i148.photobucket.com/albums/s...pse96140d7.jpg
Newtons3 07-06-2013 05:11 AM
If its factory, its a press-in stud. You will need to pull it, drill and tap the hole for screw-in studs. You REALLY should do all of them. I strongly recommend pulling the heads to do this. If you already have screw-in studs, just install 2 regular nuts, tighten then together, and use the top one to screw the stud down.
carpslayer 07-07-2013 04:35 PM
Same as what newton said but I would check that valve out to make sure its not bent.
Newtons3 07-07-2013 05:51 PM
I agree, further reason to pull the heads. What kind of spring pressures are you running?
The time now is 08:17 PM.
