Quantcast Running passenger side drop axle - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Running passenger side drop axle
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 08-07-2009, 07:17 PM   #1
ArrizX
1997 XJ Cherokee
Well, apparently its possible to flip a np231. Talked to a guy locally, who has a 97 Chev 2500 and an NP231C that he flipped because he did a straight axle in the front with a pass side drop and 37s. I was always under the assumption that you cant flip this because the oil pump would not work correctly.
Can you flip a NP231J that us wranglers and Cherokees use? The difference cant be that big between the two can it?
Even if you can flip it, I dont understand how the linkage would work anymore since its all well...... actual linkage not electronic with solenoids.
If you live in Washington State, join my Group!
http://groups.jeepforum.com/Washington_State_Jeeps
Check out my current XJ build!
Originally Posted by jeepdavetj View Post
I don't want to live on this planet anymore.
Originally Posted by My Garage
2000 F350 Tow Rig/Daily Driver
1999 F250 2wd Mud Truck project. Divorced Tcase, 3/4 tons and 40s
1997 XJ Cherokee. Cut/Caged, 6" Lift 38s ~Crash Victim~ AKA Thrasher
1999 TJ Wrangler. Retired from DD, 6" Lift on 35s needs overhaul. Project after Superduty
ArrizX is offline   Reply With Quote
Old 08-08-2009, 02:55 PM   #2
flatlander757
Now in the 937
flatlander757's Avatar
No he didnt flip it, the 231 was PROBABLY made in pass drop as well, I'd guess Chevys since it's a 231C.
My TJ is now passenger drop, read my build thread.
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Check out my Youtube channel
Pictures of it wheeling at Bill's 491
And more pics from that trip here!
flatlander757 is offline   Reply With Quote
Old 08-09-2009, 03:23 AM   #3
ArrizX
1997 XJ Cherokee
Well.... he said he flipped it??....
Why would you lie about that lol
Old 08-09-2009, 03:27 AM   #4
ArrizX
1997 XJ Cherokee
http://www.ilovejeeps.com/forums/showthread.php?p=68882
I suppose I could just find a Dana 300. Id much rather flip my current one though lol.
Old 08-09-2009, 09:50 AM   #5
flatlander757
Now in the 937
If you're serious about your Jeep build you won't run the POS chain driven weak aluminum cased oil pump driven NP231.
Get a D300 and a clocking ring so it doesn't hang down if you want to do it cheap and not kill your t-case in the process.
Build thread here.
Glock Forum
