Running cold....when hot... - JeepForum.com
post #1 of 2 Old 02-05-2006, 03:14 PM Thread Starter
Achped
2017 JK Wrangler
'99 2.5L 60,800 miles
I had a wildly fluctuating temp gauge yesterday, I'd be driving around for....hours and it'd only be at 110 degrees, then shoot up to 1/4 of the way, then back down to 100. It even varied with turns and braking!
Took apart the t-stat housing and noticed the gasket was put in backwards (gasket on the engine, not on the housing).
Fixed it and put in a new 195* t-stat.
I drove it around and it was PERFECT. I can't emphasize how much better it drove. Idled smoothly, more power. Awesome drive...but it was only on water.
Drained the radiator and filled it with 50/50 anti-freeze.
Then I was spraying something next to the jeep and accidentally got some water on the inside (near the battery/distributor) and I got a check engine light. I pulled the neg terminal and let it dry out.
Started it up and idled rough (re-learning I guess?) but my temp was no longer normal. Now it doesn't fluctuate, but it still doesn't get anywhere near 210...stays at around 180ish.
I think I have a leak in one of my heater hoses though, would this cause that? Other than that, there's nothing wrong with my cooling system.
Achped is offline
post #2 of 2 Old 02-05-2006, 03:36 PM
gumcrew2
1991 XJ Cherokee
Hmm, doesn't sound to crazy to me, I'd be happy with it really. Only down side is that it never gets to "operating temperature" so you'll lose 1-2 mpg. On mine I got a new electric fan to replace the stock electric one (ebay $65) and I built in an override switch. Now when it's in "normal" mode it still kicks in at 210 and immediately drops to like 170! I love it. On a hot day I can let it get to 220 (have the fan on "off") and then turn it on and leave it on and it'll drop to 145.
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline
89 YJ Cold Air Intake 2.5 TB darlingc Engines & Drivetrain 3 02-20-2009 07:10 PM
Cold Air Intakes! pbskidz General Jeep & Off-Road Equipment 37 03-14-2008 11:47 PM
K & N Cold Air Redrum8675 Engines & Drivetrain 6 12-23-2007 10:06 PM
2.5L skipping when cold MiloSC Engines & Drivetrain 0 08-10-2007 01:42 PM
Cold Air - K&N ontopcop Engines & Drivetrain 1 12-13-2006 08:09 PM
