Rubicon 44 axles? - JeepForum.com
post #1 of 10 Old 09-02-2013, 04:57 PM Thread Starter
treygan
Rubicon 44 axles?
I have a 1998 tj that has a 350 sbc in it and the ax-15 tranny. It currently has a dana 35 rear and dana 30 front axle. The dana 35 ring and pinion is toast and I have a line on a set of rubicon 44s and also thought about just doin the 8.8 ford in the rear. I run 35 inch tires right now and do very mild trails. Would the 44s hold up with the 35s and the 350 or would I be better off with the 8.8? Any and all advice opinions or criticism would be greatly apreciated. Thanks
treygan is offline
post #2 of 10 Old 09-03-2013, 06:22 PM
BlueRubiconrich
with the Rubicon Dana 44 axles you will be fine.
with the dana 30 front and a Ford 8.8 you will be fine to. I'd add shafts to the 30.
But the Rubicon axles will bolt right up!
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 10 Old 09-03-2013, 06:43 PM Thread Starter
treygan
If they will hold up to 35s I'm going with the rubicon axles. It'll be so much easier. Thanks.
treygan is offline
post #4 of 10 Old 09-04-2013, 07:34 PM
BlueRubiconrich
they will but don't do jumps. or you will bend the axles.
post #5 of 10 Old 09-04-2013, 07:37 PM
uberxj92
1992 XJ Cherokee
I agree. I would be more concerned about the Tranny but its pretty tough.
I run a rubi 44 front & 8.8 rear in an 88 xj with a stroker. Love it
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #6 of 10 Old 09-04-2013, 08:35 PM Thread Starter
treygan
Next year the tranny is gettin replaced with a th350 or th400 but I have to make this one last a little while. At least til march or April.
treygan is offline
post #7 of 10 Old 09-04-2013, 08:35 PM Thread Starter
treygan
No jumps. Lol. At least not on purpose.
treygan is offline
post #8 of 10 Old 09-04-2013, 08:37 PM Thread Starter
treygan
Would you guys recommend sleeving or a truss. Or should I just go with it?
treygan is offline
post #9 of 10 Old 09-04-2013, 10:48 PM
uberxj92
1992 XJ Cherokee
You said mild wheeling so they should be fine. If you feel like you need or want more then truss them
uberxj92 is offline
post #10 of 10 Old 09-05-2013, 06:53 AM Thread Starter
treygan
Alright. Thanks. I will probably just put them in for now. If I ever decide to do more offroad I can always put the truss on then.
treygan is offline
