RTV question - JeepForum.com
post #1 of 4 Old 02-01-2013, 11:47 AM Thread Starter
Vsweetser
RTV question
Anyone know what the absolute lowest temperature is for the application of standard red RTV? From some research I have come up with 77F, but that is not going to happen. The temperature plummeted and I ran into some trouble removing the manifold cover, which is where the rtv is going.
indoors is not an option. I always check the weather but impulsively I decided I needed to deal with the gasket.
Not sure if this post is where it should be,
Vsweetser is offline
post #2 of 4 Old 02-01-2013, 12:11 PM
mdm
Farm Wheeler
Manifold cover?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 4 Old 02-01-2013, 03:58 PM
seattle_yj
I'm assuming you mean valve cover, in that case use a gasket. If not then run the item to operating temp, then shut down and apply the rtv. If that's not an option just use rtv as a temp fix and do it correctly in better weather.
seattle_yj is offline
post #4 of 4 Old 02-03-2013, 11:05 AM
jokerchief462
I read all the data but they only give performance specs on cured at 75 for 5 days. Seattle YJ has your solution until you get it somewhere warm to get it to cure.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
