rough idle in drive only? - JeepForum.com
post #1 of 1 Old 12-03-2011, 09:18 PM Thread Starter
southernjeep80
the car is a 94 chevy C2500 5.7 TBI 4l80e
the problem is rough idle at running temp in drive only in park or neutral its fine.
changed IAC valve and cleaned out its bore, changed o2 sensor, changed plugs, checked TPS with multi meter seamed fine, cleaned throttle body with toothbrush and cleaner, put in new coolant temp sensor.
any idea on what could be causing this??
southernjeep80 is offline
L6 rough idle/slight hesitation off idle zjdamien Engines & Drivetrain 0 10-06-2010 07:10 PM
4.0 Rough Idle JarrettJones Engines & Drivetrain 7 04-20-2010 10:50 AM
Rough Idle csharve Engines & Drivetrain 0 06-30-2009 12:21 PM
tj rough idle JohnAxis Engines & Drivetrain 1 03-01-2008 08:03 AM
4.0 Rough Idle? ErikJordan Engines & Drivetrain 7 03-06-2003 03:30 AM
