Rough idle - JeepForum.com
post #1 of 2 Old 11-27-2013, 05:46 AM Thread Starter
Jtpeej
Rough idle
Just picked up a 2000 Cherokee 6 cyl. Truck runs great off the line and at speed. Problem is a rough idle. Watch the tach go from about 500 to 900. Seems worse when warmed up. When cold seems to maintain around 750rpm. Did a set of plugs and 2 tanks with a fuel additive. Noticed a crack on one of the fuel injectors. Would this matter? Any ideas?
Jtpeej is offline
post #2 of 2 Old 11-27-2013, 10:35 PM
uberxj92
1992 XJ Cherokee
The crack might matter. Check engine light? Try pulling codes. It could be as simple as cleaning the throttle body. Check vacuum lines make sure they're not broke or cracked.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
