Rolled my TJ and now it won't start please help!!!!!! - JeepForum.com
post #1 of 10 Old 05-14-2012, 12:40 AM Thread Starter
douglas41491
I rolled my 99 tj sahara and now it wont start! Oil came out of the intake. Idk where to start! It won't even turn over
douglas41491 is offline
post #2 of 10 Old 05-14-2012, 12:47 AM
adhdlacrosse16
2014 JK Wrangler
new oil. new coolant milky. milky of coolant or oil is bad news. then check fuel and spark. then pray its not shot
99' WJ... tank raise mesh grill homebrew cai
magnaflow 11226, banks header, bb sittin on 31s
adhdlacrosse16 is offline
post #3 of 10 Old 05-14-2012, 01:01 AM
AKGeo
Take the spark plugs out, clean them up, turn the engine over to spray the oil out of the cylinders, replace cleaned and gapped spark plugs, clean the oil off the engine, then try to restart. it'll smoke as the oil in the intake runners gets drawn back into the combustion chambers a little bit. You'll need to add some more oil, btw.
And hope you didn't bend a valve trying to start it with it hydrolocked.
AKGeo is offline
post #4 of 10 Old 05-14-2012, 01:42 AM Thread Starter
douglas41491
my intake manifold had alot of oil in it but i had a little hand pump and got most of it out. would it be a good idea to remove it and clean it or just wing it and save myself the headache
post #5 of 10 Old 05-14-2012, 03:17 AM
Technohead
Originally Posted by AKGeo View Post
. . . And hope you didn't bend a valve trying to start it with it hydrolocked.
Or worse.
You should have pulled the plugs and blown the oil out of the cylinders before turning the engine over. You could very well be on the market for a new engine now.
-Eric
Technohead is offline
post #6 of 10 Old 05-14-2012, 02:40 PM
Jkanly
Once an engine has been turned upside down, oil gathers and seeps around the piston rings into the combustion chamber and eventually flow into the intake. I doubt you damaged anything on your attempted start up due to the fact that it "wouldn't even turn over". Which leads me to believe that the cylinder was fully filled with oil, saving you in the long run. The starter motor will not have enough power on it's own to bend valves in my experience. Follow the aforementioned steps to clear the cylinder of oil, clean the plugs, and also refill the crankcase with oil.
Heres a more relevant question: At the point that the jeep was turned over, how long did it run? Did you physically turn it off by way of the key?
Chris
l _____
/l
,[____],
l---L 0lllllll0-
()_)-()_)--o-)_)
Jkanly is offline
post #7 of 10 Old 05-23-2012, 01:33 AM
HandsOn
If the starter engages but the engine won't fire, there's a good chance you tripped a fuel shut-off safety switch. These vehicles have them, correct? If so, look for a reset switch for that.
If the starter is not even engaging, then maybe some neutral safety switch or clutch interlock switch got damaged or the wires crossed? You have an automatic or manual trans?
Paul
HandsOn is offline
post #8 of 10 Old 05-23-2012, 08:02 AM
Jkanly
Paul
Jeeps do not have a inertia/reset switch.
To the OP, Did you get it started? Keep us updated
l _____
/l
,[____],
l---L 0lllllll0-
()_)-()_)--o-)_)
Jkanly is offline
post #9 of 10 Old 05-23-2012, 09:48 PM
fire2fire
You would most likely break a push rod before bending avalve stem. Pull your plugs (drain any extra oil) then take off your valvecover and make sure you didn’t bend or break and of your push rods (not that bigof a deal).
GOOD LUCK
fire2fire is offline
post #10 of 10 Old 05-25-2012, 12:42 AM
HandsOn
Well bummer. Would'a been nice if it had been something simple like that.
I'd heard that they didn't at one point in the past, but wasn't sure.
Thanks
Paul
HandsOn is offline
4.0 liter , engine , roll over valve , rolled
I got rolled for $1000 Wack Fabrication Shop 11 04-06-2010 11:53 PM
Garrett rolled the Marshtackie rrbgtt General Jeep & Off-Road Equipment 6 09-11-2009 05:43 PM
Rolled onto my side in Moab Fourbycor General Jeep & Off-Road Equipment 6 09-04-2007 09:51 PM
Rolled my jeep! whitefiesta General Jeep & Off-Road Equipment 53 01-10-2006 08:35 PM
Rolled it Jeeponrock General Jeep & Off-Road Equipment 4 01-04-2005 08:11 AM
