ring gear problems - JeepForum.com
post #1 of 3 Old 10-20-2007, 11:09 PM Thread Starter
nyoffroad
ring gear problems
After a couple of not so good popping noise and then no movement in any gear i decided to crack open the rear diff. on my d35 today. I seem to have broken every ring gear bolt off inside the ring gear so.....can i just get a ring gear and how hard is the fix?
3"Blackdiamond susp. lift
basic skid plates
Bushwacker brush and rocker guards
Rock-it air intake
more to come in future
nyoffroad is offline
post #2 of 3 Old 10-21-2007, 01:00 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
If the ring gear is clean (the pinion as well) other than the bolts and the holes in the carrier ain't wallowed, you can re-bolt the ring gear up and run a picture to check contact. If there is damage to the carrier, you will have to replace it. This means resetting the picture by changing the backlash. If the ring gear is damaged and you need to replace it, you will have to replace the pinion as well. This will entail resetting the pinion depth as well as the backlash. A job best left to the experts.
jeepdaddy2000 is offline
post #3 of 3 Old 10-21-2007, 09:02 PM Thread Starter
nyoffroad
ok well to be quite honest everything is damaged all the gear teeth have been chewed up by the bolts that snapped off, the bottom of my diff after draining was full of little metal shards the inside of the diff. cover has a bunch of deep scratches from top to bottom. It is a huge mess thanks for the response though
basic skid plates
Rock-it air intake
95' Yj Rear Differential 43 Teeth Ring Gear 14 Teeth Pinion Gear What Gears Do I Have yzman720 Engines & Drivetrain 1 06-26-2009 10:13 AM
Dana 60 Rock Ring w/o Ring Gear Hoop GrimJeeper91 Engines & Drivetrain 1 06-11-2009 12:35 PM
Broken Ring Gear Teeth SnatchBlock General Jeep & Off-Road Equipment 3 04-18-2009 11:15 AM
Best Ring Gear and Pinion Brand? Hopper_ Engines & Drivetrain 11 11-24-2007 12:36 PM
ring gear numbers? Lavacrawler General Jeep & Off-Road Equipment 2 08-05-2003 09:41 AM
