Resetting Computer - JeepForum.com
post #1 of 5 Old 04-19-2004, 07:37 PM Thread Starter
MellowJim
Resetting Computer
I'm changing out the throttle body I just recieved from Jeepers and Creepers and saw somewhere that to reset the computer the right way, to relearn, you had to disconnect the batt, then something to do with turning on/off the headlights.
Does anyone know the actual procedues for this?
Thanks,
Jim
MellowJim is offline
post #2 of 5 Old 04-19-2004, 08:56 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
just disconnect the battery for 10 minutes or so (to allow the capacitors to drain)...
on my Dodge Ram, we were also told to turn the key to start for 30 seconds while it was disconnected, but I'm not sure that ever made a difference...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #3 of 5 Old 04-19-2004, 09:31 PM
Mels95YJ
Mels95YJ's Avatar
On my YJ, I had to disconnect the positive (I think) terminal from the batter for a few minutes. I tried undoing both sides the first time, but it didn't work. Then, I read in the Haynes manual to just do the positive side. That worked.
Mel
Jeep with stuff.
Mels95YJ is offline
post #4 of 5 Old 04-19-2004, 09:31 PM Thread Starter
MellowJim
Greg
I posted the same question on the Rubicon owners forum and got the answer I was looking for. I had seen this somewhere else and just couldn't find it again.
Greg, there seems to be a couple steps missing from the 30 seconds you were told. Maybe why it didn't make a differance.
__________________________________________________ __
PCM Fast Learn Mode
I think most people know that the PCM performs several functions controlling Air Fuel ratios via Injector Pulse Width and Ignition Timing.
These “outputs” are controlled using the “inputs” received from all the sensors and then comparing these reading against a set of data tables burned into the PCM.
These “memory tables” are the brains that keep the engine running at low emissions and peak economy across the RPM band
What most people don’t know is that these memory tables change. They are “adaptive”, based on sensor readings, driving habits, engine performance and sensor tolerances.
Over time, the PCM Memory Tables become tuned to your engine.
Most folks know that disconnecting the battery for 15 to 20 minutes will reset the PCM to get rid of a Check Engine Light or Error Codes stored in the PCM.
However this DOES NOT reset the Adaptive Memory Tables in the PCM. Until recently I did not know how to do this.
This procedure first came to me from the folks at Avenger. I then verified it with a phone call to a Chrysler Engineer who had called me a year or so ago to ask about my experiences with a certain part on my TJ. I figured he owned me a favor. He had to check up on this for me. He called me back a week later and did indeed verify this procedure and what it does.
To the best of my knowledge it isn’t documented in any of the FSM.
Forced Flash
This very simple procedure will Erase the “Adaptive Memory” stored inside the TJ PCM and allow a new “Adaptive Memory” to be developed.
After performing this procedure the PCM will re-learn and store into Adaptive Memory your engines performance characteristics.
[L]Disconnect the POSITIVE battery Terminal and touch it to ground for 30 seconds. (This is to discharge the PCM capacitors, which maintain the Adaptive Memory.
Reconnect the Battery Cable
Turn Ignition Switch to the “On” position but DO NOT start the engine
Turn Headlight “On”
Turn Headlights “Off”
Turn Ignition Key “Off”[/L]
Adaptive memory has nor been flashed, or erased from the PCM.
When you start the engine it will be running off a set of pre-programmed tables that come with the PCM from the factory.
When you get the engine up to operating temperature the PCM will start to collect data for the “Adaptive Memory”.
The PCM will collect data for Adaptive Memory for the first 50 Warm-up Cycles.
Warm-up Cycle
A warm-up cycle happens when all of the following conditions exist.
Engine is running
A raise of 40F in engine temperature must occur ABOVE the engine temperature at start-up
Engine Coolant Temp must reach at least 160 F.
Once your engine has gone through 50 warm-up cycles in at least a 500-mile distance the PCM adaptive memory is set. It WILL NOT Change unless you flash it out and start all over again.
post #5 of 5 Old 04-20-2004, 11:16 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
let me rephrase...
disconnecting battery by itself, whether turning the key or not, made a HUGE difference with the problem I was having (removed a Supercharger from my Ram, and it would not idle right)...
so, it did force the PCM to relearn...I just meant there was no difference in turning the key or not...
the adaptive memory tables seem to be a whole different ballgame...thanks for the info...
Greg
1997 GC - Blinking info panel requires resetting each morning johng1 Audio, CB & Ham Radios, GPS, & Electrical 1 08-08-2009 10:26 PM
Computer Chips CherokeeTank Audio, CB & Ham Radios, GPS, & Electrical 0 04-19-2007 11:34 PM
overhead computer raysnutt18 Audio, CB & Ham Radios, GPS, & Electrical 0 03-11-2007 11:19 AM
resetting Eng lite dbusselle Street Jeep Forum 1 06-23-2006 12:59 AM
97 TJ computer tjsooley Engines & Drivetrain 1 12-18-2005 10:55 PM
