Replacing Spring Perches (Rotten) - JeepForum.com
post #1 of 2 Old 10-26-2013, 01:46 PM Thread Starter
allanbranch
1978 CJ5
I have a 1978 CJ5 with a rotten rear drivers side spring perch.
Every video I see on the internet shows the person dropping the rear axle, grinding the perches off then having to line them up correctly before welding them back in place.
Why couldn't I leave the axle in place, disconnect them from the suspension. Grind off the perches, slide the new ones in and weld them in place. This would seemingly bypass the issue of lining them up correctly.
If there is a good tutorial video or instructions please link me up, I've been searching around and can't find anything really good.
Thanks so much, have a great weekend.
FYI: I'm going to ask many stupid questions. I write software for a living, engines and Jeeps are a new technology to me. Go easy on me.
allanbranch is offline
post #2 of 2 Old 10-27-2013, 12:17 PM
rjbruzan
If you are EXCELLENT at welding out of position you could. most feel that putting the axle in place, setting the pinion angle and tacking it in place. Than remove or rotate it weld it in and put back together.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
