Replacing clutch, Need help! - JeepForum.com
post #1 of 5 Old 05-06-2012, 03:13 PM Thread Starter
Robob
My clutch has been slipping pretty badly, lately. So I decided to replace the clutch with a Luk clutch kit and while I have the transmission/transfer case out im going to do a SYE kit also.
Everything was going smooth until I got to the 2 top bolts on the bell housing. My jeep is a 2000 with the 4.0L and a NV3550. I ended up rounding off the bolt on the drivers side. I dont want to do the same to the passenger side bolt as its a lot harder to access. Any tips on how I should go about it?
Thanks
2000 Wrangler TJ yellow- 35's MT/R, 3" Zone lift, Advanced adapters sye kit with Tom Woods driveshaft, Savvy/Currie adjustable rear UCA
1995 Wrangler YJ black- 2.5in lift, 31's - Sold :(
2003 Honda CBR600RR- Full arrow exhaust system
1982 Vespa sport 100- 135cc malossi kit, Leo vince exhaust
Robob is offline
post #2 of 5 Old 05-06-2012, 09:03 PM
jnicewan
Are they torx bolts or something? What are you using to take them out, are you sure you are using the right size tools/socket? Anyway after you get them out you can go to a hardware store and replace them with new bolts.
jnicewan is offline
post #3 of 5 Old 05-07-2012, 06:52 AM Thread Starter
Robob
It looks to be a reverse torx bolt, I was using a 12 point socket. It felt snug when I had it on there, but I guess it is probably my own fault for not using the proper tool. I will be replacing them with new bolts though.
Robob is offline
post #4 of 5 Old 05-07-2012, 07:41 AM
jeepinsoldier10
Get yourself a set of reverse Torx sockets. You probably didn't strip it out as bad as you think. I had the same issue and once I put the proper socket on it came right out. Even after the 12 point socket slipped on it
jeepinsoldier10 is offline
post #5 of 5 Old 05-07-2012, 03:55 PM Thread Starter
Robob
Well I picked up the torx sockets today. I will work on the jeep tomorrow and hopefully I can finish up this job. Sucks not having a vehical lol
Robob is offline
Squishy clutch then the clutch just locked up completely is it the master, slave or ? GPII Engines & Drivetrain 1 11-25-2011 07:36 PM
replacing my 231 PR3TZ3L Engines & Drivetrain 3 08-11-2010 07:56 PM
Is a clutch a clutch.......No varying degrees of (good better best) Rubi Unlimited Engines & Drivetrain 10 11-26-2008 11:26 PM
manual bellcrank clutch vs Hydraulick clutch jphillips13 Engines & Drivetrain 1 07-09-2008 09:25 PM
Replacing a Tub Black Hills TJ General Jeep & Off-Road Equipment 3 11-23-2007 06:50 PM
