Replacing the 12E Torx bellhousing bolts - JeepForum.com
post #1 of 3 Old 04-28-2014, 12:18 PM Thread Starter
Baburl
What should I replace those two Torex bolts with? Grade 8 hex bolt and washer? I was thinking there would be a replacement bolt set for the bellhousing but my search has come up empty. Thanks for the help
Baburl is offline
post #2 of 3 Old 04-28-2014, 03:04 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Asked & answered.
3/8"-16 thread, match length underhead. Hex head screws okeh, washers not strictly necessary (but not a bad idea, either.)
You'll find my accumulation of screw sizes on my site - start at www.kelleyswip.com/tech.html, and follow the links from there. Questions like this are why I've been trying to amass that data and get it all in one place...
(NB: SAE5 or SAE8 will work, as will CRES. You don't need massive strength in that location. I've also had good luck putting studs in those holes, but it can be a bit of an exercise getting the nuts started...)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #3 of 3 Old 05-07-2014, 07:25 PM Thread Starter
Baburl
Originally Posted by 5-90 View Post
Asked & answered.
Thanks! I was wondering if I had to use washers or not. Thanks again for the help.
Baburl is offline
