Replacement u-joint snap rings - JeepForum.com
post #1 of 3 Old 11-02-2009, 06:43 PM Thread Starter
JiffyPark
So where in the heck do you get replacement Spicer u-joint sanp rings? I'm in the process of rebuilding my front drive shaft and the u-joints are fine so I'll be reusing them but I need new snap rings. Tried looking online and came up empty. Then tried calling a couple of local places and they were no help.
JiffyPark is offline
post #2 of 3 Old 11-02-2009, 06:51 PM
flatlander757
Are they the snap rings from the CV joint side the ones you need?
If so I am going to be rebuilding my driveshaft with different joints and whatnot so if you like I can take all those snap rings off and mail them to you.
PM me your mailing address if you want them, I think I can just put the clips in an envelope and send them your way. They are from my stock TJ front shaft, should be about 50k miles on them.
If you want brand new, I don't know where you would find those.
Perhaps just buy some cheap u-joints from the parts store for the clips and have some spare u-joints.
Try calling Tom Woods as I bet he can help out, when I was running one of his shafts he sent me a ton of grease fittings for the shaft since I lost one of them on a trail
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #3 of 3 Old 11-02-2009, 11:15 PM Thread Starter
JiffyPark
It's for all 3 u-joints on the front shaft. That is very generous of you. If I don't find anything local I might take you up on the offer.
U Joint Replacement UTmike Engines & Drivetrain 56 08-19-2015 07:01 PM
Replacement Beadlock Rings pachary Tires & Wheels 1 11-09-2008 05:43 PM
front DS cv u-joint replacement/grease Muddeprived Engines & Drivetrain 1 01-07-2008 06:33 AM
SYE Install (snap rings) JSBlu974X4 Engines & Drivetrain 1 03-06-2007 10:42 PM
Is it ok to reuse snap and lock rings on output shaft?? blacktjsport Engines & Drivetrain 3 12-21-2006 07:49 PM
