replaced lifters now what? - JeepForum.com
post #1 of 5 Old 01-10-2009, 08:03 PM Thread Starter
reeksofrezin
when i replaced the lifters several were collapsed but there was no wear on the base that rides on the cam. i did not notice any abnormal wear on the pushrods, or rockers. after start up it was pretty quiet but as it reaches temp it starts to tick again. not bad but not totally fixed. what did i miss? i will pull the valve cover tomorrow and inspect all again . any suggestions? i do not have an exhaust leak and i assume that the cam is ok because of no wear on the lifters.
reeksofrezin is offline
post #2 of 5 Old 01-10-2009, 08:08 PM Thread Starter
reeksofrezin
i posted this on the tj spot but i haven't gotten much response. there is more info on that post. i probably should have started this here. sorry i am fairly new to the internet thing.
post #3 of 5 Old 01-11-2009, 04:13 AM
rab986
If you are certain that it is valve train noise, then you might check to see if you are getting oil up to your rockers. What is your oil pressure at normal operating temperature?
rab986 is offline
post #4 of 5 Old 01-11-2009, 08:32 PM Thread Starter
reeksofrezin
just under 40 psi. how do i check, just run it and see if it pumps out of the rocker?
post #5 of 5 Old 01-25-2009, 11:36 AM
4jeepers
Yes you can do that for a moment, you should get a lot of oil so have someone start vehicle while you check! Take it from there and good luck!
4jeepers is offline
lifters and bad cam? jepperson Engines & Drivetrain 0 02-17-2009 05:11 PM
would bad lifters cause this? BigDumbBear Engines & Drivetrain 3 01-28-2009 06:28 PM
4.0L lifters joe73m Engines & Drivetrain 2 05-11-2008 08:26 PM
Gas lifters Psyker Fabrication Shop 3 04-25-2007 06:44 PM
Cam and lifters...out with the old.. Airborne4X4 Engines & Drivetrain 5 04-11-2006 07:52 PM
