Renix 4.0 Conversion Help Won't Start - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Renix 4.0 Conversion Help Won't Start
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 11-24-2012, 11:30 PM   #1
davidmthomas97
I recently swapped a 4.0 into my YJ, used the same harness and ecu from the engine. I redid the bulkhead to my underdash wiring, I have the fuel pump solenoid working correctly along with the pump itself. I was able to drive the jeep i got it out of before i took the engine out. I converted ev erything used same flywheel and kept the CPS on there but it is not starting. I never messed with the distributor or wires. Thanks
davidmthomas97 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 06:03 AM   #2
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What year 4.0 and wiring?
Do you have spark?
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2012, 12:36 PM   #3
davidmthomas97
Yeah I have spark and it came out of a 90 Cherokee
Unread 11-25-2012, 12:47 PM   #4
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pump in the tank? Where did you get that?
Unread 11-25-2012, 06:08 PM   #5
davidmthomas97
I bought the setup for a 92-95 20 Gal. Tank
Unread 11-25-2012, 07:11 PM   #6
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That should be okay. Only way to be sure is to check fuel pressure at the rail with a gauge.
Unread 11-26-2012, 12:46 AM   #7
davidmthomas97
I don't have a guage to check it but it sounds normal
Unread 11-26-2012, 05:58 AM   #8
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm not understanding how you can hear fuel pressure. Am I missing something?
Unread 11-29-2012, 09:18 PM   #9
davidmthomas97
No i can hear the pump and when i had the pump out it put out a pretty good amount of pressure when I would pressure test the new lines with it. But I came down to the issue of vacuum. I am only getting about 5lbs and I have every plug i can see on the engine and the diagram plugged and still getting the same pressure.
Unread 11-30-2012, 06:43 AM   #10
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Vacuum is measured in inches, not pounds. How are you checking it?
Unread 11-30-2012, 11:37 PM   #11
davidmthomas97
I have a vacuum gauge hooked in with a T on one of the lines coming from the nipple by the air cleaner
Unread 12-01-2012, 05:09 AM   #12
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Not picturing that. Make sure you're in a line/fitting that for sure is getting actual intake manifold vacuum.
4.0 , conversion , jeep , wrangler yj
