-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   Renix 4.0 Conversion Help Won't Start (http://www.jeepforum.com/forum/f19/renix-4-0-conversion-help-wont-start-1442000/)
davidmthomas97 11-24-2012 10:30 PM
I recently swapped a 4.0 into my YJ, used the same harness and ecu from the engine. I redid the bulkhead to my underdash wiring, I have the fuel pump solenoid working correctly along with the pump itself. I was able to drive the jeep i got it out of before i took the engine out. I converted ev erything used same flywheel and kept the CPS on there but it is not starting. I never messed with the distributor or wires. Thanks
cruiser54 11-25-2012 05:03 AM
What year 4.0 and wiring?
Do you have spark?
davidmthomas97 11-25-2012 11:36 AM
Yeah I have spark and it came out of a 90 Cherokee
cruiser54 11-25-2012 11:47 AM
Pump in the tank? Where did you get that?
davidmthomas97 11-25-2012 05:08 PM
I bought the setup for a 92-95 20 Gal. Tank
cruiser54 11-25-2012 06:11 PM
That should be okay. Only way to be sure is to check fuel pressure at the rail with a gauge.
davidmthomas97 11-25-2012 11:46 PM
I don't have a guage to check it but it sounds normal
cruiser54 11-26-2012 04:58 AM
I'm not understanding how you can hear fuel pressure. Am I missing something?
davidmthomas97 11-29-2012 08:18 PM
No i can hear the pump and when i had the pump out it put out a pretty good amount of pressure when I would pressure test the new lines with it. But I came down to the issue of vacuum. I am only getting about 5lbs and I have every plug i can see on the engine and the diagram plugged and still getting the same pressure.
cruiser54 11-30-2012 05:43 AM
Vacuum is measured in inches, not pounds. How are you checking it?
davidmthomas97 11-30-2012 10:37 PM
I have a vacuum gauge hooked in with a T on one of the lines coming from the nipple by the air cleaner
cruiser54 12-01-2012 04:09 AM
Not picturing that. Make sure you're in a line/fitting that for sure is getting actual intake manifold vacuum.
The time now is 01:22 AM.
