Renix 4.0 Conversion Help Won't Start - JeepForum.com
post #1 of 12 Old 11-24-2012, 10:30 PM Thread Starter
davidmthomas97
I recently swapped a 4.0 into my YJ, used the same harness and ecu from the engine. I redid the bulkhead to my underdash wiring, I have the fuel pump solenoid working correctly along with the pump itself. I was able to drive the jeep i got it out of before i took the engine out. I converted ev erything used same flywheel and kept the CPS on there but it is not starting. I never messed with the distributor or wires. Thanks
davidmthomas97 is offline
post #2 of 12 Old 11-25-2012, 05:03 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What year 4.0 and wiring?
Do you have spark?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 12 Old 11-25-2012, 11:36 AM Thread Starter
davidmthomas97
Yeah I have spark and it came out of a 90 Cherokee
post #4 of 12 Old 11-25-2012, 11:47 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pump in the tank? Where did you get that?
post #5 of 12 Old 11-25-2012, 05:08 PM Thread Starter
davidmthomas97
I bought the setup for a 92-95 20 Gal. Tank
post #6 of 12 Old 11-25-2012, 06:11 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That should be okay. Only way to be sure is to check fuel pressure at the rail with a gauge.
post #7 of 12 Old 11-25-2012, 11:46 PM Thread Starter
davidmthomas97
I don't have a guage to check it but it sounds normal
post #8 of 12 Old 11-26-2012, 04:58 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm not understanding how you can hear fuel pressure. Am I missing something?
post #9 of 12 Old 11-29-2012, 08:18 PM Thread Starter
davidmthomas97
No i can hear the pump and when i had the pump out it put out a pretty good amount of pressure when I would pressure test the new lines with it. But I came down to the issue of vacuum. I am only getting about 5lbs and I have every plug i can see on the engine and the diagram plugged and still getting the same pressure.
post #10 of 12 Old 11-30-2012, 05:43 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Vacuum is measured in inches, not pounds. How are you checking it?
post #11 of 12 Old 11-30-2012, 10:37 PM Thread Starter
davidmthomas97
I have a vacuum gauge hooked in with a T on one of the lines coming from the nipple by the air cleaner
post #12 of 12 Old 12-01-2012, 04:09 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Not picturing that. Make sure you're in a line/fitting that for sure is getting actual intake manifold vacuum.
4.0 , conversion , jeep , wrangler yj
