Removing plugs from the head - JeepForum.com
post #1 of 10 Old 10-23-2013, 09:08 PM Thread Starter
DaemonForce
I hate whenever I run into this kind of thing but for me it's an ongoing problem when simply dissembling a tired engine. I've cleared out a 4.0L block and the last struggle I had to solve by taking it to a machine shop. Apparently the fact that I'm the only builder that doesn't have a torch means that I still have to get help from others to remove something as small and insignificant as the small pipe plugs that take a 5/16" square.
This is where I'm having trouble only it's no longer the block but the head. If any of you have ever disassembled the HEAD you would know what I'm talking about. Those 6 probably 5/8" square fitting plugs are stuck to the head almost as if welded on. I've tried manually pulling them but fear I might strip them. I've tried putting an air wrench on them at 140psi but they don't budge. Do these need to be removed the same way as the other pipe plugs? These are a real pain and I'm pretty sure I need to remove them before shipping the head off to the hot tank.
DaemonForce is offline
post #2 of 10 Old 10-24-2013, 06:59 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I've never removed them. Why?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 10 Old 10-24-2013, 07:55 AM Thread Starter
DaemonForce
I'm doing a COMPLETE teardown of the 4.0L and I'm extremely paranoid about any surprises I might have after giving this engine a bath. I'm extremely comfortable modifying components in the block but the head is quite serious. Anyone can throw together a 4.6/4.7L monster by swapping a few engine components but I want to redo the entire thing from top to bottom just because I'm sick of fighting my grandpa and everything he did to my 4.2L that eventually led to it overheating and blowing up.
Just to clear up any vague points, all you need to really know is that I've fought an engine non-stop because of "professional mechanic" noise and once I get this engine built, that's the end of that noise. If it blows up, my fault. If not, I don't have to put up with harassment from my family anymore. There's a sort of validation thing in there but mostly, if anything goes wrong with it, I'll immediately understand what and why.
Right now the plan is to remove everything non-essential to the engine, get the block and head in the hot tank and then start measuring, boring and building. I can't afford to lose momentum anywhere in this process because my time is so precious. I should have been finished with this engine and out of this dump last year. I have until the end of this year and if I screw this up I'm done with the car, as in just pancake it.
post #4 of 10 Old 10-24-2013, 07:59 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
IMHO, you're being overzealous and overreacting about previous experiences. Your choice, but I've built a few 4.0s.
One I built from 3 different engines. Runs great to this day. Never removed those plugs.
post #5 of 10 Old 10-24-2013, 08:03 AM Thread Starter
DaemonForce
Okay, maybe I don't have to remove the pipe plugs but if there were some kind of pinhole leak or anything stupid like that, what would be the process for fixing that?
post #6 of 10 Old 10-24-2013, 08:07 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pinhole leak where? Those are tapered pipe plugs. Quite thick.
post #7 of 10 Old 10-24-2013, 08:31 AM Thread Starter
DaemonForce
You're right. I guess it couldn't happen. This is probably the only topic about this in existence which means nobody even thinks about doing this. I'll move on.
post #8 of 10 Old 10-24-2013, 07:07 PM
BIGBADWOLF
Save your energy for the big things. Those plugs were never meant to be removed....they were part of the casting process.
BIGBADWOLF is offline
post #9 of 10 Old 10-24-2013, 08:09 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yep. True stuff^^ right there.
post #10 of 10 Old 10-24-2013, 09:09 PM
rjbruzan
May be its time to get a torch set up?
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
