remote oil radiator - JeepForum.com
post #1 of 3 Old 02-16-2002, 07:21 PM Thread Starter
evilpsych
evilpsych's Avatar
remote oil radiator
k guys, this is a related post to the one about electric fans. How hard is it to run a oil cooling radiator to the engine and mount it in front of the radiator. I'm guessing it's a fitting that you can directly screw into the oil filter hookup similar to a remote filter setup, then the passthrough to the filter.. anyone do this? i havent seen a writeup on any of the site for this, I'm also interested in a transmission cooler as well.. if they exist or if you even need one for a manual tranny..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 3 Old 02-16-2002, 07:41 PM
Mat&His97XJ
rustys offroad sells one, maybe you can find some info there
I'm out like a fat kid playing dodgeball..... Matt
Mat&His97XJ is offline
post #3 of 3 Old 02-24-2002, 02:03 AM
MuddyCJ5
evil, Your right. It is just a fitting that replaces the the filter, similar to a remote setup. They are a pretty good investment, not hard to install. Your engine will run much cooler (it takes a huge load off of the engine coolant) and oil will do a better job. It's one the first things i do to anything i plan to keep. Happy Trails, Dan
MuddyCJ5 is offline
amp 12v remote? Runnerboy Audio, CB & Ham Radios, GPS, & Electrical 13 03-26-2007 04:17 PM
Remote Mount CB? morpheus122 Audio, CB & Ham Radios, GPS, & Electrical 3 01-29-2007 08:21 PM
amp remote wire murgg Audio, CB & Ham Radios, GPS, & Electrical 9 05-28-2006 01:33 PM
Remote Gas-man Audio, CB & Ham Radios, GPS, & Electrical 2 04-08-2006 09:53 AM
Remote Starter jcollins Audio, CB & Ham Radios, GPS, & Electrical 3 04-05-2006 12:41 PM
