Regearing question - JeepForum.com
post #1 of 4 Old 05-21-2013, 07:39 PM Thread Starter
Spud100
Regearing question
My 99 tj came from the factory with 4.10 gears and 205/75 tires (27 inch diameter). I now have 31s (about 30.5 diameter). Calculating the equation to get me back to stock ratio works out close to 4.56 gears yet everything I read says 4.56 is too low for 31s. What am I missing? Please help.
Spud100 is offline
post #2 of 4 Old 05-29-2013, 12:58 PM
RWKHaus
1990 XJ Cherokee
Well you have a 4cyl if they are 4.10 stock.
If you have added weight and the larger heavier wheels and then tires, the 4.56 should be perfect.
Brook "He kissed me at KOH, you should ask him about itů"
RWKHaus is offline
post #3 of 4 Old 05-29-2013, 08:48 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Install a tach and see what your spinning at your true target speed. Ie, if your looking to run at 55MPH (actual, your speedo will be slower due to the larger tires), see what the engine is turning. Then decide where the sweet spot in your torque curve is and try to target it.
jeepdaddy2000 is offline
post #4 of 4 Old 06-29-2013, 09:00 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I'd hold off on regearing. My 4cyl ran fine with 31's. You know thats not the end size tire, so wait if you can. I went to 33's and decided that was enough. The math for 33's on a 4 cyl says 4.88, so that's what I did. That was great for 33's. When I later went to 35's, it wasn't really a gear problem, but became a power problem. It was tough for the 4 cyl to spin the larger mass tires to accelerate, even though the tire size was only 6% larger. I then went to a V6 and kept the 4.88s. Life is great now (since the motor in 2004) on and off road.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
