Regearing for the first time... Progressing
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |||
Disgruntled Jeepforum'er
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
Well folks, I tried to regear my HP D30 with a friend last weekend but we didn't get very far. Tonight I'm going to try to regear the axle alone. While it might be harder, I figure it'll be easier to concentrate and work at a leisurely pace when on my own time.
Ultimately I'm slapping an ARB w/ Yukon 4.10 into a HP Dana30. All new components. 1) Pinion Baffles, I've heard that most people don't run them. Been told they decrease lubication @ slow speeds. True? Any drawback to not using them? 2) Carrier preload. I measured .065" in play for the carrier. .015 was added until things felt good. So I currently have .030 in shims on each side. How does this preload look to you? [yt]C1xGmUEFT6w[/yt] Any input is appreciated, either post up or get me through AIM (same screen name)
-Ryan Google Voice (or the number Grape calls when drunk): 845-476-8182 Quote:
#2 | ||
Attempt 1
Carrier 40/40 Backlash 0 (Certainly could be worse) Pinion Depth 54 Drive ![]() Coast ![]()
#3 | ||
Attempt 2
Carrier RGS 30 NRGS 50 Backlash 3 Pinion Depth 54 No Pattern Taken Attempt 3 Carrier RGS 20 NRGS 59 Backlash 11 Pinion Depth 54 No Pattern Taken
#4 | ||
Attempt 4
Carrier RGS 25 NRGS 54 Backlash 8 Pinion Depth 54 Drive ![]() Coast ![]()
#5 |
we are watching you...
#6 | ||
haha, good. Thought I was talking to myself for the past few hours.
Post 4 edited with pics. Whatcha think? Get the pinion a little more towards the carrier? It seems that the ~55 for the pinion was a good guess/start, heh.
#7 | ||
One concern I have is the sharp line on the drive side. My backlash is optimal right now, but I can't say that it looks like a clean flat on flat gear contact.
#8 |
i don't know crap about them, just watching you
BTW that cat gives me the creeps |
#9 | ||
Heh, well atleast we're both on the same skill level when it comes to regearing.
#10 |
imo the pinion is to close add a shim to the pinoin and it should take that sharp line away.
1999 jeep tj 4.0 5spd R/C 4"x lift 35-12.5-15 swampers 8.8 detroit locked with 4:88s Dana 30 front with 4:88 i live i ride i am JEEP! |
#11 | ||
Alright, will try. Hopefully it'll center out that pattern.
#12 | ||
Setting it up with 61 for pinion depth. Once that is changed will my backlash need to be adjusted as well?
#13 | |
Never Forget
what write up are you using?
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers Quote:
www.cityprofile.com |
#14 | ||
A combo of pirate4x4's, yukons, arb, and a few random ones from misc places.
I'll spew out links once I finish.
#15 | |||
Shifting carrier shims before I check pattern.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
