Regearing for bigger tires... - JeepForum.com
post #1 of 2 Old 08-05-2008, 05:50 AM Thread Starter
roadracer321
Im new to Jeeps and to this forum, and I want to get a lift and 33s for my 05 Wrangler Sport. My question here is, the 05 has a 6 speed tranny now. The gear ratio is now different compared to the old 5 speed trannys. I think mine is something like a 4.46:1 where as the older ones are 3.83:1... I could be wrong. But if this is true, will I need to regear, or will this ratio be ok? Unfortunately, I travel a lot in my jeep, 60-70mph is not uncommon, and I do climb several steep hills at those speeds. So I dont want to have to use 4th to climb. I referenced the gear ratios from this site. http://www.conceptcarz.com/vehicle/z..._Wrangler.aspx
Thanks in advance.
roadracer321 is offline
post #2 of 2 Old 08-05-2008, 07:02 AM
Pillswoj
This is the best place to look at gear ratios. http://www.grimmjeeper.com/gears.html
You don't say what ratio you have now, is it 3.07 or 3.73. You can check your ratio by looking for the tag @ the 9 o'clock position on the differential cover, the second line of numbers sould begin with the ratio.
There has been some discussion that with the 6 speed and 33's 4.10 might be the better option due to the lower first gear and overdrive of 0.84. With my five speed, 4.56 is definitely the right gear.
If you have 3.07 gears you will definitely want to regear sooner rather then later. If you have 3.73's it may be liveable long term but it will depend on the highway performance you want and the type of wheeling you do.
Friends don't let Friends run Bosch
Pillswoj is offline
new to bigger tires, need help brodon Tires & Wheels 8 01-31-2010 07:21 PM
bigger wheels, then eventually bigger tires grim-reaper Tires & Wheels 0 12-23-2008 10:03 AM
Regearing after lifting with bigger tires Finulanu Tires & Wheels 19 08-01-2008 02:13 AM
Bigger Tires claytonandson Tires & Wheels 5 05-07-2006 12:53 PM
i want bigger tires! raider jeep Tires & Wheels 3 09-10-2002 10:24 AM
