Rears - JeepForum.com
post #1 of 16 Old 04-03-2013, 11:11 AM Thread Starter
pslack86
Rears
I have a 98zj v8 jeep don't know what rears I have in it how do I tell where can I look at on the rear
pslack86 is offline
post #2 of 16 Old 04-03-2013, 11:23 AM
mdm
Farm Wheeler
As far as I know, your ZJ should only have one rear.
Look here for info on your rear and front.
http://www.jeepforum.com/forum/f13/z...u-post-880249/
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 16 Old 04-03-2013, 11:43 AM Thread Starter
pslack86
Talked to auto part store there is 3 diff rears
pslack86 is offline
post #4 of 16 Old 04-03-2013, 12:15 PM
eduardostewart
if you're good at eyeballing this might help
eduardostewart is offline
post #5 of 16 Old 04-03-2013, 12:28 PM Thread Starter
pslack86
Thank u big help
pslack86 is offline
post #6 of 16 Old 04-03-2013, 12:37 PM
Flajeeper1
1987 YJ Wrangler
MDM gave you information for your ZJ. If you have the
93-98 V8 (5.2L or 5.9L) Grand Cherokee's
96-98 ONLY
D44a "aluminum center section" rear axle •Differential Location: Centered
•Stock axle splines: 30 spline shafts, no upgrades to spline count available
•Lug Pattern: 5 on 4.5"
•Width: 60.5" from wheel mounting surface to wheel mounting surface
•Notes for D44a: Not a bad axle with 33-35" tires, some care needed for the larger end, has been known to handle 37's with care. The aftermarket support is very limited for this axle due to the aluminum center section. The center section is very similar to the unit in the corvette. Many people replace the axle due to the limited gear ratio's available and the extremely limited availability of any traction device such as a locker.
What are the 3 rear ends the auto parts store states you have? You have a V8 engine and it's a 1998 correct? It should be a D44.
Next please fill out your profile to the best of your knowledge.
Flajeeper1 is offline
post #7 of 16 Old 04-03-2013, 01:23 PM Thread Starter
pslack86
30 44 35
pslack86 is offline
post #8 of 16 Old 04-03-2013, 01:32 PM
Flajeeper1
1987 YJ Wrangler
D30 is your front differential, D35 is a rear differential for a 6 cyl. jeep, D44 is a rear differential for an 8 cylinder jeep. You have indicated that you have the 8 cylinder engine and your rear differential is a D44. What are you doing to the diff?
post #9 of 16 Old 04-03-2013, 02:12 PM Thread Starter
pslack86
The seal on pinion leaking bad
pslack86 is offline
post #10 of 16 Old 04-03-2013, 02:19 PM Thread Starter
pslack86
That's my front rear that's what I got
pslack86 is offline
post #11 of 16 Old 04-03-2013, 02:22 PM Thread Starter
pslack86
pslack86 is offline
post #12 of 16 Old 04-04-2013, 09:05 AM
Flajeeper1
1987 YJ Wrangler
Ok. Let's work on terminology. You have in a 4 wheel drive a front differential and a rear differential. You are showing your front differential in the picture. Is the differential leaking where the driveshaft connects to it?
If, so who is going to do the work to replace the seal, someone else or you?
post #13 of 16 Old 04-04-2013, 09:09 AM
Flajeeper1
1987 YJ Wrangler
Looking at your picture is your steering linkage bent? Post a picture showing your steering, front left wheel to right.
post #14 of 16 Old 04-04-2013, 09:17 AM Thread Starter
pslack86
Front left
pslack86 is offline
post #15 of 16 Old 04-04-2013, 09:18 AM Thread Starter
pslack86
I'm gonna do it where the drive shaft hooks to it
pslack86 is offline
