rear end troube - Page 4 - JeepForum.com
post #46 of 62 Old 10-16-2013, 05:09 PM
uberxj92
1992 XJ Cherokee
Sounds reasonable. Is that why Chevy uses those gear driven lockers?
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #47 of 62 Old 10-16-2013, 08:35 PM
Evildriver-3
That eaton g lock screws up.constantly, lol got 1 of them being removed this week too.
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #48 of 62 Old 10-19-2013, 11:10 AM
sheriff1680
If I may offer my opinion, the D35 is actually a pretty good axle and performs well within its design limits. This axle was used in millions of TJs, XJs, YJs and ZJs over a long period of time. This includes all non towing package ZJs with a 5.2 V8. If it was anywhere near as bad as what is regurgitated on the internet, we would see jeeps with broken axles littering the sides of the road daily across North America.
I constantly see posts about the tubes being so weak.....same tubes as a 44. Coke can metal brackets....same brackets as a 44. Ring and pinion junk...tell that to the bunch running S35 kits at Johnson Valley.
The D35 will break. No doubt. Most failures come from flex across the length of the housing. This will snap shafts near the splines or break spider gears. 99% of these failures are from pushing it beyond its design limits. They don't just explode for no reason when you back out of your driveway.
The vast majority of people offroading a jeep do moderate trails. The D35 is fine for that. I have a stock D35 with LSD, stock shafts and 33x10.50s. And I've run it with a 5.2 V8 for the past 3 years. I push it fairly hard so I carry spare shafts. Haven't broke yet and if it does I'll fix it and keep going. If I snap a shaft every once in a while, that's an acceptable failure rate to me. I am confident enough in it with the way I drive that I'm going to run the Rubicon next summer.
The D35 is fine for most people and situations. Jeep understood that when they put it in most jeeps. If you're breaking yours constantly then upgrade to something stronger, but there's no reason to try to convince the people that don't break theirs that they need a stronger axle.
2014 Wrangler Sport S 2 dr
1997 TJ, 5.2 Magnum V8, 46RE, NP231, 4:10's.....
I hear voices.
sheriff1680 is offline
post #49 of 62 Old 10-21-2013, 08:19 PM Thread Starter
Buschmann
1983 YJ Wrangler
This.
Cept I did break mine and prolly will again LOL
Buschmann is offline
post #50 of 62 Old 10-21-2013, 10:06 PM
sheriff1680
And I might break mine. Along with lots of other parts I have broken. And I fix them and keep on going....
I hear voices.
post #51 of 62 Old 10-22-2013, 09:11 AM
Evildriver-3
Make that two, got another one to do this week, and again like the bad rap the 35 gets the g lock being used out of parameters of design these things break left and right.
]=Supershafts=[
post #52 of 62 Old 11-06-2013, 11:15 AM Thread Starter
Buschmann
1983 YJ Wrangler
Put the spartan locker in last night. ...chirping away as intended. ..no more shifting while turning lol
post #53 of 62 Old 11-10-2013, 06:54 PM
wildkardboyz
So. Im so confussed with all the gibberish. . Is it ok to have a locker on a dana 35? If so what would you put on and also a d30 what would you put on there. I just bought the jeep and it has 307 gears ill be opening it up and doing 373 I have off roaded before and know not to hop the tires. stuff goes boom. But I just started taking my boys playing with me and dont plan on doing crazy stuff with them in the rig. But would like to not worry about slipping. Thanks in advance
Pain... is .... weakness... leaving the body....
wildkardboyz is offline
post #54 of 62 Old 11-10-2013, 08:32 PM
uberxj92
1992 XJ Cherokee
What model year? I only ask because if you're going to lick it and regear it soon. Then there maybe easier options that are cheaper and faster.
But, It depends on your type of off roading. If you are general wheeling then I would limited slip style in the rear and a mini spool up front. Got alot reviews in line about this set up. I have 2 friends that run this set up in xj's here in Florida and they love it
uberxj92 is offline
post #55 of 62 Old 11-11-2013, 12:30 AM
wildkardboyz
Well it is a 97 sport 4.0
post #56 of 62 Old 11-11-2013, 03:19 PM
uberxj92
1992 XJ Cherokee
Wrangler I take it. Ok if you get the Dana 30 out of a 93-98 grand Cherokee v8 (zj) that will give you high pinion and large joints and 3.73 gears. That'll save you money for sure. And time.
For the rear I'm not sure if s zj rear will bolt up in a tj but if it does then you can get the matching rear with disc breaks.
My suggestion would be to grab a ford 8.8 out if an explorer. You'll have to spend a little time and money converting it but it'll have disc brakes, a limited slip and, 3.73 gears. The 8.8 is stronger than a 35. But if you are easy on your gas pedal and don't pound on any axle too much they'll last.
You can regear what you have, here in Florida that runs about $500 or so per axle. Then a locker in the 35 will cost about $250 to have installed over the locker price.
I paid $150 per axle at a u pull it yard. The front is easy to swap I paid a welder $200 to install my rear. I paid $150 (free shipping ) for the install kit for the 8.8.
uberxj92 is offline
post #57 of 62 Old 11-11-2013, 03:35 PM
biffgnar
biffgnar's Avatar
Neither a ZJ front or rear is bolt in to a TJ. XJ front and other TJ/LJ axles are only bolt in options.
Romney in 2020!
biffgnar is offline
post #58 of 62 Old 11-11-2013, 03:46 PM
wildkardboyz
Ok so what is a high pinion gear. Im new to the jeep world.
post #59 of 62 Old 11-11-2013, 06:00 PM
uberxj92
1992 XJ Cherokee
Zj & xj & tj all have same front.
I have put 2 zj fronts into 2 xjs and 1 into a tj.
uberxj92 is offline
post #60 of 62 Old 11-11-2013, 06:05 PM
uberxj92
1992 XJ Cherokee
High pinion is preferred because the pinion gear runs on the top if the ring gear better contact point. And usually a better drive shaft angle.
Low pinion is on the bottom if the ring gear. Lower angle on drive shaft. Which sometimes cause issues with lifts
uberxj92 is offline
