Rear end is making a roaring noise - JeepForum.com
post #1 of 4 Old 04-13-2009, 06:06 PM Thread Starter
miiller
Hey guys I just bought a 99 Grand Cherokee Laredo and the rear end makes a roaring noise when driving it. It lets up just slightly when you let off the gas. I believe that I have a seal out because grease is leaking where the drive shaft meets the differential. I checked the grease and it needed some but was not what I thought was enough to cause something to go bad. What do you think this could be? Does grease run through the whole axle out to the wheel bearings? Ive got a few more questions but we will leave it at that for now. I'm new here so I would really appreciate the help. Thanks
miiller is offline
post #2 of 4 Old 04-13-2009, 07:44 PM
Heap-O-Jeep
sounds like you have pinion bearings on thier way out thus the leaking seal because the bearings arent holding it centered. i also have a roaring noise but unlike you my rearend roars all time. (not just on decel or accel) my diff guy says its probably the gears going bad. my pinion seal is not leaking and at 108k miles and original seals i would say he is probably right. if i re-gear i am going with an HP d30 front axle a 1993-94 front ds and match the 3.73:1 gears. among other wants to upgrade hummmmm....
WHY DO YOU NEED TO KNOW WHERE YOU ARE GOING?
Heap-O-Jeep is offline
post #3 of 4 Old 04-13-2009, 08:49 PM Thread Starter
miiller
Any idea what those bearings cost?
miiller is offline
post #4 of 4 Old 04-13-2009, 09:17 PM
Heap-O-Jeep
if you have never rebuilt a differential before you dont have a clue on whats involved. there is critical measuring and applying torque to the bearings (which is called pre-load) if you dont have the special tools and the know how then you are in for big trouble if you decide to do it yourself. it, needs to go to a qualified technician at a shop that you know isnt going to rip you off. its going to take inspection and diagnosis of the gears and bearings. its not a simple job as in changing brakes. it can cost you a couple hundred bucks to do the job plus parts. if the bearings are worn bad chances are the gears could be worn bad and/or chipped or broken.
cat making funny noise the_fuzz Engines & Drivetrain 7 03-13-2009 06:43 PM
Axle making noise That1guy Engines & Drivetrain 6 01-12-2009 02:48 AM
What's with CAI Kits Making Noise??? Maverick906 General Jeep & Off-Road Equipment 11 04-16-2007 09:56 AM
Dana 35 is making noise... OneCleanYj Engines & Drivetrain 10 03-11-2007 06:39 PM
amp making a funny noise oake Audio, CB & Ham Radios, GPS, & Electrical 8 11-20-2002 09:31 PM
