rear end gears - JeepForum.com
post #1 of 9 Old 12-02-2012, 06:28 PM Thread Starter
kjg26
kjg26's Avatar
rear end gears
Im trying to determine my rear end gear. I raised the rear axle and rotated the tire 1 entire rotation. The rear shaft spun 1 5/8. The trans was in neutral and both rear tires were in the air.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 9 Old 12-02-2012, 07:07 PM
BlueRubiconrich
You need to mark a tire and the rear drive shaft
most YJ's came with 3:07's, 3:54's and 4 cyl's came with 4:10's
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 9 Old 12-02-2012, 07:09 PM Thread Starter
kjg26
kjg26's Avatar
I counted whole revolutions on the tire. For one tire revolution I had 1 5/8 turn in the shaft.
kjg26 is offline
post #4 of 9 Old 12-02-2012, 07:15 PM
BlueRubiconrich
best bet go to your Jeep dealer with your VIN theny can tell you what you Jeep came with.I can tell you you don't have 4:10 gears unless they swapped them out. Other thing to do remove rear cover count pinion gear teeth and the ring gear.
post #5 of 9 Old 12-02-2012, 07:25 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Raise ONE rear wheel, spin the wheel TWICE while counting driveshaft revolutions.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 9 Old 12-02-2012, 08:07 PM Thread Starter
kjg26
kjg26's Avatar
Why twice?
kjg26 is offline
post #7 of 9 Old 12-02-2012, 08:19 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by kjg26 View Post
Why twice?
The driveshaft drives the ring gear, the ring gear rotates the carrier, the carrier houses the differential (spider) gears that drives both of the axle shafts. Spinning only one tire twice accounts for the non-spinning tire.
Max
Mean Max is offline
post #8 of 9 Old 12-02-2012, 08:26 PM Thread Starter
kjg26
kjg26's Avatar
So if I got JUST over 1.5 turns of the drive shaft with one turn if the tire. I more than likely have 3.07s
kjg26 is offline
post #9 of 9 Old 12-02-2012, 09:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
That would be my thought, based on what you did.
Max
Mean Max is offline
