Rear Driveshaft compatibility for 93 YJ -
post #1 of 3 Old 10-21-2013, 02:12 PM Thread Starter
My Rear driveshaft busted and now I'm looking for a replacement part, but as I search, I am seeing that there are different lengths of shafts. My part is off a 93 wrangler, 4 cylinder, 4x4, manual trans, with a 3" susp. lift, and 4" block lift. The shaft from ubolt to ubolt is about 15 & 3/8" long, and about 22" total with the NP231 universal slip yoke. What I was wondering was, is it possible to put a rear driveshaft from a 6 cylinder, manual into our 4 cylinder manual, or are there any other driveshafts that are compatible with ours?
kawenam808 is offline
post #2 of 3 Old 10-22-2013, 09:20 AM
Center to center of joint ? driveline is all measured center to center, not sure what a u bolt measurement is
If you need 15" you could find a longer shaft visit your local driveline shop and have it shortened.
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
Long Island Motorsports Association
Evildriver-3 is offline
post #3 of 3 Old 10-24-2013, 12:16 PM Thread Starter
Thanks, but i found one the same length as mines. I was talking about the length the to shaft itself, not including the slip yoke. Plus we only have one machine shop here and they charge an arm and a leg for that kind of work.
driveshaft length
In order to be able to post messages on the forums, you must first register.
