Rear diff grinding 94 yj - JeepForum.com
post #1 of 7 Old 03-17-2013, 05:02 PM Thread Starter
MapeDogg
There is a grinding sound coming from my rear diff when there is no load on the driveline. As long as I am accelerating or decelerating in gear there is no noise. When I reach a cruising speed or coast in neutral there is a fairly loud grinding sound that is worse the higher the speed.
MapeDogg is offline
post #2 of 7 Old 03-17-2013, 07:27 PM
seattle_yj
Pull cover. Inspect. Magnet through oil. Check carrier, pinion, yoke for movement.
seattle_yj is offline
post #3 of 7 Old 03-17-2013, 08:43 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
also, if you have posi-trac, make sure you have the correct rear end fluid, and vice versa.. posi lube in a regular non posi rear, or even in a locker, will grind and crunch like crazy..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #4 of 7 Old 03-17-2013, 09:21 PM
dlutz94
Take the diff cover off and drain it and put new fluids. My buddy had the same problem and he let it go and ended up blowing it.
dlutz94 is offline
post #5 of 7 Old 03-18-2013, 04:02 PM Thread Starter
MapeDogg
Thanks for the help ya'll! I'll try these suggestions and see what happens.
MapeDogg is offline
post #6 of 7 Old 03-18-2013, 04:12 PM
SuperStew11
Had similar problem in my wife's 94 ZJ after I changed the fluid, posi-differential needs an anti slip additive you only get from Dealers
SuperStew11 is offline
post #7 of 7 Old 03-19-2013, 09:32 AM
Evildriver-3
Check your pinion nut, a quick look chock the wheels, and then put it in neutral to relieve any load on the shaft, grab it at the end yoke and see if you have ANY movement up and down or in and out, it should only have some turning movement but NOTHING in any other direction.
If it has any movement other than what it should , either the nut has loosened, or the bearings are in need of replacement.
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
