rear axle not aligned on frame - JeepForum.com
post #1 of 8 Old 05-04-2011, 08:22 AM Thread Starter
Ripper3494
I have a 2003 TJ with a 2.5 skyjacker lift. I did not install the lift, but since that time, my son and I have been doing as much maintenance as we can ourselves. We now have a lift in the garage.
Just recently, my kid pulled my transfer case to get it worked on. As I looked at the jeep from the rear, the rear axle does not appear to be centered on the jeep frame. I looked at the track bar and nothing seems to be bent. The lift was put on a couple of years ago, and it's been looked at by several jeep experts.... nobody has ever made a comment that it was off (and I never noticed it before).
I've included some pictures of the wheels (although it doesn't do it justice.. the difference is probably a couple of inches towards the passenger's side).
Any thoughts on what to look at would be greatly appreciated.
Thanks!
Ripper3494 is offline
post #2 of 8 Old 05-04-2011, 08:23 AM
Mayfair_Jeeper
Mayfair_Jeeper's Avatar
Do you have an adjustable rear track bar? If not, that is why the axle is off like that. Its no big deal.
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline
post #3 of 8 Old 05-04-2011, 08:28 AM
theducksguts
It is not going to be centered when the suspension is unloaded on the lift. What is it like when on the ground? Sounds like you may need to adjust the track bar.
Check out my
theducksguts is offline
post #4 of 8 Old 05-04-2011, 09:15 AM Thread Starter
Ripper3494
I'll read more threads on how to adjust the track bar to compensate for this. Being relatively new to this, I don't know the difference yet between a big deal and no big deal.
Thanks for the advice.
post #5 of 8 Old 05-04-2011, 10:23 AM
BlackBellamy
BlackBellamy's Avatar
As the previous poster pointed out, it's NOT going to look centered while up on the lift. Put it down on the ground and then check it out.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #6 of 8 Old 05-04-2011, 10:38 AM Thread Starter
Ripper3494
Yep, got it. Thanks again.
post #7 of 8 Old 05-04-2011, 08:27 PM
Technohead
Originally Posted by Ripper3494 View Post
. . . We now have a lift in the garage. . .
-Eric
Technohead is offline
post #8 of 8 Old 05-05-2011, 09:28 AM Thread Starter
Ripper3494
At 17, my son crawling on the cold wet floor under cars is a rite of passage, but at 50, been there/done that. It got old for me real quick. What use to be easy (shimmying under a car and back out several times on my back) has now become more of a "roll" than a "shimmy". Couple that with the blackouts that accompany getting back up on your feet after laying for an hour or two on the cold floor and all of a sudden a garage lift is worth the price.
BTW, putting the jeep back on the floor corrected the alignment issue as some of you predicted. Thanks!
alignment , axle , lift
Axle Widths Charts?! Info for axle swap options for Front/Rear Paraleyes Engines & Drivetrain 1 03-10-2011 12:09 PM
Rear Frame Rot + Little Question _JEEP_ Fabrication Shop 12 07-09-2009 07:26 PM
2wd Rear Axle to 4wd Rear Axle Swap awilkie Engines & Drivetrain 1 01-20-2009 01:49 PM
Rear Frame Repair Mr.B Fabrication Shop 0 03-11-2006 05:02 PM
Can't get aligned Scotta Tires & Wheels 1 04-14-2003 12:59 PM
