Rear .Axle - JeepForum.com
post #1 of 7 Old 10-05-2008, 06:34 PM Thread Starter
Curt99
Rear .Axle
Hello all,
I just got my Jeep TJ back with a new clutch, a retaining pin blew apart and caused internal damage to other clutch parts so I have a new clutch. $819.00.
My Dodge Ram 1500 4x4 is making a howling noise from the rear end. It gets louder when I accelerate and stops when the truck is stopped. When the engine is revved in neutral the sound is not there and the engine sounds fine. I don't think the transmission, u-joints or drive shaft is causing the noise. Could it be the differential or rear wheel bearings? What the test for the wheel bearings if I pull the diff cover and it's fine? The bottom of the differential case appears wet but not dripping and we have just returned from Moab, UT pulling a small trailer.
Any thoughts will be greatly appreciated.
Thanks,
Curt
Curt99 is offline
post #2 of 7 Old 10-06-2008, 12:00 AM
willness33
Sounds like bearings to me. Could be on the wheel end, carrier or pinion. Taking a closer look at the bearings and races and feeling for play is the only to tell for sure.
willness33 is offline
post #3 of 7 Old 10-06-2008, 01:07 PM Thread Starter
Curt99
Yes, I'll check out the bearings, the fluid level in the differiential is ok and has been changed recently.
Thank you,
Curt
Curt99 is offline
post #4 of 7 Old 05-24-2012, 03:45 AM Thread Starter
Curt99
Thank you,
Curt
It's been quite a while but the end of the story is I had the differential rebuilt and all is well. Except the transmission went out and died. Now I have running truck and a few weeks ago I had a complete tuneup with lube and oil change. It runs great now. It still gets 10 mpg though. It had 92,000 on it. I don't think even a new engine will get better milage. That's just what the truck gets.
Curt99 is offline
post #5 of 7 Old 05-24-2012, 09:40 AM
Technohead
Does the rear driveshaft have a center bearing? If so then start there.
-Eric
Technohead is offline
post #6 of 7 Old 05-24-2012, 03:07 PM
kcaverly
He got it fixed already.
Sounds right though, my father-in-law's Ram 1500 had the same howling noise from the rear and one night when the Jeep was down I borrowed it to run into town for pizza. On the way back howling turned into grinding and forward motion stopped. Pulled it apart and found a bunch of bearing rollers loose in the rear axle.
He had just driven it from Ontario down to Florida and back and this was its first trip from the house since he got back.
Kevin
1993 Jeep YJ - 350 Chevy TBI, SM465, NP241, 14B SF LSD, 10B
kcaverly is offline
post #7 of 7 Old 05-25-2012, 03:43 AM Thread Starter
Curt99
Kevin
Yeah it's a real pain but I was lucky to save the ring and pinion gears. The rest was toast. Then later when I was enjoying the truck the transmission went out. It has 97K on it, I checked today. After a tuneup it runs smooth and is very comfortable. With gas prices the long distance towing of my rv trailer is about out though.
Curt99 is offline
2wd Rear Axle to 4wd Rear Axle Swap awilkie Engines & Drivetrain 1 01-20-2009 12:49 PM
YJ Rear Axle in YJ? 00Vert Engines & Drivetrain 3 05-31-2006 01:12 PM
Rear Axle???? 2002XCrwlr Engines & Drivetrain 3 05-15-2006 11:27 AM
I got my new rear axle! webdr Engines & Drivetrain 2 05-13-2006 07:13 PM
Can you regear just the rear axle? BIGNUTT General Jeep & Off-Road Equipment 12 12-16-2005 12:24 PM
