Rear Axle???? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Rear Axle????
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 05-15-2006, 12:08 AM   #1
2002XCrwlr
Rear Axle????
I just bought a 2002 Wrangler X, I6, Auto and I need to find out what type of front and rear axle I have.... Anyone have a clue on where I need to look????? I might be getting a free rear locker but I need to find out if it is going to fit....
2002XCrwlr is offline   Reply With Quote
Unread 05-15-2006, 12:23 AM   #2
TJ on the Rocks
Up front You will have the Dana 30 .
The rear will either have a Dana 35 or a Dana 44 . See this picture to identify your rear axle .
Notice the 35 has more of a round shape to the diff cover and a rubber fill plug . The 44 has more of an angular shaped cover and has a metal , screw in fill plug
This is all assuming the axles are of the original equipment
[SIZE="7"][SIZE="7"][SIZE="5"][URL="http://www.atozfabrication.com/catalog/"][B][CENTER][SIZE="5"][COLOR="Red"]AtoZ F[/COLOR][COLOR="White"]abric[/COLOR][COLOR="Blue"]ation
[/COLOR][/SIZE][/CENTER]
[CENTER][B][/SIZE]
[SIZE="4"][/URL][/B][COLOR="Red"][/SIZE][/SIZE][SIZE="3"][URL="http://www.stickylee.com/catalog/index.php"]www.stickylee.com[/URL][/COLOR][/SIZE][/B][/CENTER][/SIZE]
TJ on the Rocks is offline   Reply With Quote
Unread 05-15-2006, 12:25 AM   #3
2002XCrwlr
Thanks....
Thanks for the visuals... It'll make it 10 times easier to figure it out... I appreciate the help... If its a 44 on mine I'm set... I'll get both!
Unread 05-15-2006, 11:27 AM   #4
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
If you have just the standard X model, you'll have the D35 rear. The D44 was not even an option on these models.
The only X models that got the D44 rear were a few special packages, such as the Rocky Mountain Edition.
Wheelin98TJ is offline   Reply With Quote
