Reanix block vs HO block - JeepForum.com
post #1 of 3 Old 04-08-2004, 10:12 PM Thread Starter
ST33LR4T
i am currently running a 94 4.0L HO block in my yj. i have a line on a 89 4.0L reanix block.
i want the 89 to build a stroker with so i have as little downtime as possible.
can i use the 89 in my yj? ive been told the blocks are pretty much the same...ive also been told the mounting points on the reanix are different then the HO.
ST33LR4T is offline
post #2 of 3 Old 04-12-2004, 11:38 AM
75SV1
I can't definately state on this swap. If your vehicle was a Cherokee or Comanche, the reverse of this swap has been done. I bought a 95 4.0L HO block off a guy out of a TJ(for the head). He had an 01 block sitting there he couldn't use. He said the motor mounts wouldn't bolt up. I think on that engine, they didn't drill and tap some of the bosses towards the front of the engine. I am not sure if they have those bosses on the 87-90 Renix blocks, or if they are drilled. During that time, the Wrangler used the 4.2 (258).
Tom
75SV1 is online now
post #3 of 3 Old 04-13-2004, 09:36 AM Thread Starter
ST33LR4T
ive had one shop tell me its different, then ive had another shop plus some other people tell me it will swap. so im gonna take my chances and pick one up.
ST33LR4T is offline
ARB Snatch Block vs. Gunnebo Johnson Snatch Block Rigged General Jeep & Off-Road Equipment 4 06-21-2009 10:45 PM
4.0 block vs. 4.2 block jukeyard Engines & Drivetrain 14 08-29-2007 06:34 AM
small block and big block difference tjboy Engines & Drivetrain 3 03-03-2005 09:35 PM
Big Block NBDave Engines & Drivetrain 2 02-18-2005 05:52 AM
AMC 360- big block or small block? Bret-o Engines & Drivetrain 3 01-02-2003 06:33 PM
