Read my gear pattern - JeepForum.com
post #1 of 8 Old 06-18-2013, 09:58 PM Thread Starter
Bskank
Installing G2 4.88's in a 8.8. Backlash is .011 but I'm thinking I need more shim on the pinion, what do you think? This is my first regear and axle swap attempt.
Bskank is offline
post #2 of 8 Old 06-18-2013, 10:01 PM Thread Starter
Bskank
And
Bskank is offline
post #3 of 8 Old 06-19-2013, 03:04 PM
Macanator
Supporting Member
Add .005 may even need a little more then that but that's where I would start.
Mac
Macanator is offline
post #4 of 8 Old 06-19-2013, 09:28 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Here's the chart from the FSM.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #5 of 8 Old 06-20-2013, 01:26 AM
Evildriver-3
You're out to far on the pin, and you HAVE to check the pattern with the bl set right, you want to be .006 / .008 unless the ring gear itself says it wants a specific bl setting. then run the pattern
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #6 of 8 Old 06-21-2013, 10:42 AM Thread Starter
Bskank
Thanks guys, I added .010 and it looks pretty good.
Bskank is offline
post #7 of 8 Old 06-23-2013, 06:05 PM
freeskier93
Backlash specs are not universal, depends on the axle and what the gear manufacture specifies. The 8.8 generally as a higher backlash spec, my Nitro gears had a specification of .011" to .016". I personally thought that was high and settled on .009".
freeskier93 is online now
post #8 of 8 Old 06-23-2013, 10:12 PM
Evildriver-3
The actual 8.8 acceptable specs are from 8 to 15, however I haven't set a 8.8 past 8 yet. however I did say if the ring gear has a specific bl # put on it then adjust it to that.
Also on a off-road use vehicle that is going to put load and unload issues on the gear you really don't want a bl beyond 10
]=Supershafts=[
