-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   Read my gear pattern (http://www.jeepforum.com/forum/f19/read-my-gear-pattern-1538383/)
Bskank 06-18-2013 08:58 PM
1 Attachment(s)
Installing G2 4.88's in a 8.8. Backlash is .011 but I'm thinking I need more shim on the pinion, what do you think? This is my first regear and axle swap attempt.
Bskank 06-18-2013 09:01 PM
1 Attachment(s)
And
Macanator 06-19-2013 02:04 PM
Add .005 may even need a little more then that but that's where I would start.
Mac
GilaMtnJeep 06-19-2013 08:28 PM
Here's the chart from the FSM.
http://www.jeepforum.com/gallery/dat...dium/Gear1.jpg
Evildriver-3 06-20-2013 12:26 AM
You're out to far on the pin, and you HAVE to check the pattern with the bl set right, you want to be .006 / .008 unless the ring gear itself says it wants a specific bl setting. then run the pattern
Bskank 06-21-2013 09:42 AM
Thanks guys, I added .010 and it looks pretty good.
freeskier93 06-23-2013 05:05 PM
27 Attachment(s)
Backlash specs are not universal, depends on the axle and what the gear manufacture specifies. The 8.8 generally as a higher backlash spec, my Nitro gears had a specification of .011" to .016". I personally thought that was high and settled on .009".
Evildriver-3 06-23-2013 09:12 PM
The actual 8.8 acceptable specs are from 8 to 15, however I haven't set a 8.8 past 8 yet. however I did say if the ring gear has a specific bl # put on it then adjust it to that.
Also on a off-road use vehicle that is going to put load and unload issues on the gear you really don't want a bl beyond 10
The time now is 03:22 AM.
