Re-gearing my 1991 yj - JeepForum.com
post #1 of 5 Old 02-12-2011, 11:48 PM Thread Starter
jrayjeepcj2a
I have a 4 or a 4.5 inch suspension lift with a 3 inch body lift. I am currently running 35x12.5 pro comp all terrains on the stock axles/gears. I havent really researched it much, i figured someone on hear could give me a hand. What kind of gear ratio would be best with the set up i have (4cyl amc 150, stock transmission, etc.). Also, my four wheel drive will engage into 4 low, however the front axle is not catching to rotate the tires. I really have no knowledge of the mechanical components inside the differential or the transfer case but im gotta learn somehow. If anybody has any advice for me that would be great!
jrayjeepcj2a is offline
post #2 of 5 Old 02-13-2011, 08:20 AM
KLT88YJ
As far as your re-gearing I'd go with 4.88's in the Dana 30 & 35. That's the lowest gear set those axles can accommodate. Factory has 4.10's which is good for stock and possibly up to a 31 or 32" tire, but it gets Very difficult to maintain speed on the highway. You'll probablly want to look into a Dana 44 rear or a Ford 8.8 out of an explorer. They'll hold up better than the Dana 35 with the increased weight and stress of the 35" tires.
For the transfer case/ front drive shaft issue, the shift fork collar on the axle disconnect might not be fully engaging? There's a cover plate on the back right side of the front axle, this is the disconnect. If they loose vacuum or proper connection they will not function properly. Fixes are (least expensive to most$$): junkyard late model Cherokee or 97+ Wrangler passenger side axle shaft, posi-lock or warn chromoly cad delete shafts. Hope this helps.
KLT88YJ is offline
post #3 of 5 Old 02-13-2011, 09:11 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Go to the YJ tech section and read the FAQ.
All your questions are covered there, as well as the next 25 you were thinking of asking...
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #4 of 5 Old 02-13-2011, 10:22 AM Thread Starter
jrayjeepcj2a
Alright, i appreciate it, hopfully this will help, im currently trying to graduate from college so hopefully i'll have some time to look into your advice. i really have no income so funds come and go as they please, haha
post #5 of 5 Old 02-13-2011, 10:46 AM
KLT88YJ
Well the Nutter is pretty much free! Good luck with your build!
KLT88YJ is offline
will 2004 wrangler rim fit 1991 cherokee oneoclock Tires & Wheels 1 09-13-2009 09:35 PM
1991 XJ swap crf450ish Engines & Drivetrain 0 08-05-2009 12:01 AM
1991 renegade fenders??? Goobersbro Fabrication Shop 5 11-05-2008 03:53 PM
Sensor Resistances For 1991 Up Please shinigami Audio, CB & Ham Radios, GPS, & Electrical 0 06-27-2008 03:24 PM
nv3350 into a 1991 yj? iking87 Engines & Drivetrain 10 11-20-2006 03:42 PM
