Radiator Dumb question - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Radiator Dumb question
Memorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-21-2004, 04:26 PM   #1
Cynic
the other night i was at walmart i picked up an air filter....i got home and installed it but while i was under the hood i heard a hissing from the radiator cap but the engine temp was normal before i shut it off...and a little bit of antifreeze along the top rim of the radiator...like it was coming from the cap a little.....the overfill was empty....do radiator caps go bad and if they do would it do this?....
if i need a new cap should i order a new billet one (which i dont really care how it looks) or are the pep boys caps work just as well?
btw this is a new radiator (8000 miles new anyway) but old cap....
Cynic is offline   Reply With Quote
Unread 04-21-2004, 06:50 PM   #2
Silver yj
The caps do go bad,when you get mone make sure its for the rite amount of pressure.
Silver yj is offline   Reply With Quote
Unread 04-21-2004, 07:08 PM   #3
Cynic
ya i just ran out to salvo and picked up a new one made by stant.....the stant book said it was part # 11234 which is 18 psi...when i compared the caps the center of the old one didnt spring like the new one....so i think it was blowing out excess pressure instead of going into the overflow....
Stant
Part # 11234
Cost. 3.99 us
if anyone else needs to know this info....
