Radiator with 4.3 chevy engine swap - JeepForum.com
post #1 of 3 Old 04-25-2007, 10:51 PM Thread Starter
redrock82
I have a 1982 CJ7. When I purchased it the owner had the original 151 cubi inch 4cyl swaped with a 4.3L Chevy V6, however the radiator is the stock one for the four cyl. Does anyone have any suggestions for a radiator that will mate up with the CJ7 and handle the cooling needs of the 4.3L Chevy. I have not over heated so far but with the hot summer in California ahead I want to get it replaced.
redrock82 is offline
post #2 of 3 Old 04-26-2007, 12:01 PM
David K.
I am in the process of finishing a 2002 4.3L into a YJ. I used a radiator for $200 from extreme radiator.com. It is a conversion rad so it bolted right in and the hoses are on the correct side for hte chevy engine.
I haven't had it running yet. So I will tell you that I don't know for a fact how well it works. I am also using a novak elec fan.
David K. is offline
post #3 of 3 Old 04-27-2007, 12:27 AM Thread Starter
redrock82
Thanks for the info. Do you by chance have the part number from extreme radiators?
Looking for help in engine swap choices, Chevy, Jeep, or any others rosenb1995yj Engines & Drivetrain 4 07-02-2009 11:42 PM
what radiator in 97 TJ with V-6 chevy MorningWood Engines & Drivetrain 0 11-23-2008 03:24 PM
Chevy swap on XJ 89'XJ Engines & Drivetrain 4 09-28-2006 12:51 PM
new radiator for chevy 350 grandman97 Engines & Drivetrain 3 01-12-2006 05:04 AM
Chevy 350 Swap??? Bethlehem Engines & Drivetrain 11 08-02-2005 08:51 PM
