Questions about Dana 60 - JeepForum.com
post #1 of 7 Old 11-20-2013, 12:08 PM Thread Starter
604_yamamoto
I have a dumb question about the Dana 60 rear axle swap I've been thinking of doing on my 07 Rubicon. Isnt the Dana 60 on th 08 J8 milspec an 8 bolt hub? My dumb question is what to do about the spare? If I have my stock 44 in the front with 5 bolt, and 8 bolt in the rear then how do you work with having one spare? How does tire rotation work?
604_yamamoto is offline
post #2 of 7 Old 11-20-2013, 12:42 PM
biffgnar
biffgnar's Avatar
Sounds like you need to be looking for an adapter to convert the lug pattern on the front. No idea if anybody makes that combo though.
Romney in 2020!
biffgnar is offline
post #3 of 7 Old 11-20-2013, 03:04 PM
Evildriver-3
You need to make them both the same, problem is which way do you want to go, mod the rear axle and make it match the front or do the front and match the back.
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #4 of 7 Old 11-20-2013, 03:55 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
A couple years ago I needed a set of adapter/spacers. This place worked out well: http://www.airbagit.com/5-Lug-To-8-L...ers-s/1581.htm
Joe Dillard is offline
post #5 of 7 Old 11-22-2013, 05:47 AM Thread Starter
604_yamamoto
Adapter spacers, well that answers my question, thanks. I would probably make the rear 5 bolt like the front but with the spacers, wouldn't the rear wheels stick out slightly farther than the front?
post #6 of 7 Old 11-22-2013, 08:40 AM
biffgnar
biffgnar's Avatar
How wide is the 60 you are getting? In particular relative to your front? Whichever place you put the spacers it will make that axle wider.
Romney in 2020!
biffgnar is offline
post #7 of 7 Old 11-22-2013, 09:47 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Depends on the WMS to WMS (wheel mount surface to wheel mount surface) width measurement on your D60. If you can find one that matches or very close to your stock axle width it will be a non issue. The generally run "full width" of 65in or greater. so yeah, it may stick out quite a bit.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
