post #1 of Old 07-01-2006, 11:55 PM Thread Starter
Oregon YJ
question on ring and pinion dana 30 95 yj
Would any one know the differance for a ring and pinion gear set for a yj and tj dana 30. they do both use the same carrier and are of the same gear ratio (3.73)
Their is a differance in the ring and pinion and any help with this would be greatly appreciated. I am looking into putting the tj gears into the yj dana 30 but do not whant to get ino doing it untill I am certain the swap would work.
Thanks
Oregon YJ
Oregon YJ is offline
post #2 of Old 07-02-2006, 06:17 AM
rustyCJ
pinion is different, TJ uses a crush sleeve and YJ uses shims
YJ uses reverse cut gears, TJ uses standard cut gears
can not interchange!
http://www.jeeptech.com/axle/d30.html
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #3 of Old 07-02-2006, 09:00 AM Thread Starter
Oregon YJ
Thanks for the great info, Rustys CJ
Thanks Again.
Oregon YJ
Dana 60 Rock Ring w/o Ring Gear Hoop GrimJeeper91 Engines & Drivetrain 1 06-11-2009 12:35 PM
Dana 30 - installation of ring and pinion gear CJ780 Engines & Drivetrain 1 03-15-2009 06:39 PM
Which ring and pinion? harley2003rkc Engines & Drivetrain 4 09-29-2008 07:42 PM
XJ Dana ring pinion 01xjsport Engines & Drivetrain 2 03-11-2008 05:22 PM
ring &pinion Nikos Engines & Drivetrain 2 03-27-2006 01:17 AM
You may not post new threads
You may not post replies
