Is pulse air check valve neccesary? - JeepForum.com
post #1 of 5 Old 03-20-2013, 06:18 AM Thread Starter
larock
1983 CJ7
The pump air check valve for my jeep was rusted in half and they stopped making it ten years ago so finding a replacement has been impossible. I know it's part of the emissions system an I know I don't have to pass emissions do is it even necessary? When its not in the engine runs a lot louder so if its not necessary can I just plug it up with something? And if so any ideas for what to use as a plug?
larock is offline
post #2 of 5 Old 03-20-2013, 07:05 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I think it's still available from parts stores....Post a pic.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 5 Old 03-20-2013, 03:36 PM
NonRubicon
If you don't need the pulse air system in place for emissions testing, you can just remove all the pulse air parts. It'll clean up the engine compartment noticeably.
For plugs you can use vacuum line caps or rubber stoppers.
NonRubicon is offline
post #4 of 5 Old 03-20-2013, 07:41 PM Thread Starter
larock
1983 CJ7
Do you know all of what I can take out? I really like the sound of de-cluttering my engine area but don't want to remove anything I shouldn't. Not sure if its simple ive tried to read up on it but ill take any advice you've got.
larock is offline
post #5 of 5 Old 03-20-2013, 09:15 PM
NonRubicon
Here's a a vacuum diagram (not all inclusive) of the 4.2L engine:
For more diagrams and 4.2L info go to: Adventures Under the Hood. Pretty much all you need to know about the 4.2L engine in the CJ and YJ. I recommend you check it out before doing anything. You'll at least understand what does what.
Caveat: I have removed the pulse air system from my Jeep, but it was in conjunction with removing the whole vacuum system in preparation for installing the Howell TBI. Please feel free to verify any of this with someone who has done just the pulse air delete.
I'd start with the check valve assemblies and solenoids - those are the easiest to locate. Both connect at the air filter housing - cap or plug the filter housing ports. For one pulse air line, the other end connects upstream at the exhaust manifold. You'll need to weld closed the manifold port - I welded a bolt into mine - might be easier if the manifold is removed. The other pulse air line connects downstream at the catalytic converter. You'll need to crimp and weld that cat port shut. You can also remove the decel valve. You'll want to keep the vacuum reservoir in the loop, so be sure to reroute the line so it stays functional.
The simplest way to do all this is to disconnect the part, trace the disconnected line to the nearest junction and place a cap at the junction. From there you can determine if the lines can be further simplified.
