pull broken ring gear and keep driving? - JeepForum.com
post #1 of 3 Old 04-11-2013, 07:12 AM Thread Starter
gotmudnj
Has anyone ever done this? Im thinking if i was to break a ring gear in woods can i pull the ring gear and reinstall carrier and keep on driving? Just a thought. Whats your thoughts on that...
**** Happens.....
~~GOT MUD CENTRAL NEW JERSEY 4x4 ~~
gotmudnj is offline
post #2 of 3 Old 04-11-2013, 03:41 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
While doable, you would have to completely disassemble the diff to get the ring gear out. Might be easier to drop the offending driveline and very gently ease the rig out to the road.
jeepdaddy2000 is offline
post #3 of 3 Old 04-11-2013, 04:06 PM
222Doc
222Doc's Avatar
The better way is to remove axles. Take the inner axle off with the Ujoint. Replace the outer stub axle and bearing. remove the Drive line. Now you have 2x4 that can roll.
You have to remove the axles anyway to get to the carrier. So just stop at the axles. Plug the outer housing with a rag, rap in a plastic bag.
Thats for the front.
The rear well if you can drive it but the more you drive it the worse it gets. I could see taking the ring out if I had to go along way. But it is amessy job out on a trail and some places you better?should anyway. have a spill kit.
222Doc is online now
