problems with ignition - JeepForum.com
post #1 of 3 Old 10-12-2009, 11:02 AM Thread Starter
jkl9964
I am having a problem with the ignition/engine. I go in my jeep when it is cold( which is a 97 4cyl auto 70,000 switched the motor out) and I turn the ignition and it doesnt fire for mabey two seconds, and then I turn it off and turn it back on and it fires up great, or I turn the key but not all the way and leave it for a few seconds and then turn it off and turn it back on and it fires right up. Do you think it is something to do with the fuel injection, not sure can I get a little help
jkl9964 is offline
post #2 of 3 Old 10-12-2009, 11:26 AM
mdm
Farm Wheeler
There is an anti-drain back valve in the fuel regulator. This valve keeps the fuel from draining out of the fuel line when the engine isn't running. Since this valve isn't working properly each time you start the engine after it has been sitting for a while the fuel pump must refill the line and build pressure before the engine can start.
The valve is part of the pump which is the fuel tank. The tank must be dropped in order to replace the pump. Unless you have other issues you might want to just put up with letting it sit with the key on for a moment before trying to start the engine.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 3 Old 10-12-2009, 11:30 AM
XJMuscle98
Check valve is bad as mdm said.
Confirm by running it for a while and then park it, check fuel pressure and then compared the next morning.
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
ignition switch problems Budlight Audio, CB & Ham Radios, GPS, & Electrical 3 02-25-2009 06:03 AM
MSD ignition on 4.0 Matt Gertsch Engines & Drivetrain 0 02-09-2006 05:00 PM
new engine ignition problems klamath offroad Engines & Drivetrain 1 03-24-2005 09:22 PM
ignition Q's boozehound Engines & Drivetrain 3 04-01-2002 01:52 PM
304 V8 WITH GM HEI IGNITION CJ junky Engines & Drivetrain 0 09-22-2001 09:18 PM
