Problem with something. HELP ME PLEASE (bucking and jerking with acceleration) - JeepForum.com
post #1 of 6 Old 05-08-2010, 01:54 PM Thread Starter
iDriveYJ
So when i got the jeep i realized at a certain point in every gear the jeep would start jerking and bucking violently as if i were in the wrong gear but i was not in the wrong gear. over time i realized it does it between acceleration and coasting. when i go from acceleration to coast it clunks some then its fine when i go to accelerate again it start jerking. i have replaced vacuum line fuel filter spark plug distributor cap and nothing is fixing it i'm thinking that mabey my transmission has to much play in gear i have no idea any suggestions will help currently im replacing the spider gears because the just busted.
iDriveYJ is offline
post #2 of 6 Old 05-08-2010, 03:13 PM
GilaMtnJeep
GilaMtnJeep's Avatar
May be way off here, but have you checked your trans mount?
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 6 Old 05-08-2010, 03:35 PM Thread Starter
iDriveYJ
No I haven't . I have already pulled the trans out once to replace the slave cylinder It was doing it before so I don't know if I put it together wrong. But I will deff check. Also I replaced the o2 sensor
iDriveYJ is offline
post #4 of 6 Old 05-08-2010, 04:19 PM Thread Starter
iDriveYJ
i checked the trans mount and sure enough the rubber bushings were extremely loose i dont know if it has fixed anything or not my jeep is still out of duty now. thanks
iDriveYJ is offline
post #5 of 6 Old 05-09-2010, 05:04 PM
crzdmnky
1978 CJ5
U- Joints, I didnt see that you said anything about them? Hows your bolts that are connecting your Tranny to your Engine block? are they tight, and all they all accounted for?
crzdmnky is offline
post #6 of 6 Old 05-09-2010, 07:30 PM Thread Starter
iDriveYJ
the drive shaft is brand new and the u joints are too. the bell housing is missing one bolt thats no problem im pretty sure its just the trans tourque bar that bushing bolt broke so ill get it replaced an see if it helps. i was always convinced it was fuel problems
iDriveYJ is offline
driveline , needs fixing , problem , trouble , troubleshooting
my YJ is bucking and the RPMs jump and fall generaljeep Engines & Drivetrain 6 04-06-2010 11:12 PM
97 jeep wrangler bucking bkfranklin22 Engines & Drivetrain 4 07-13-2009 10:31 AM
acceleration delay... KeyserGogo Street Jeep Forum 5 04-19-2008 12:46 PM
Wrangler 2.5L Kicking and Bucking at higher RPMs MrHappy Engines & Drivetrain 3 03-26-2007 01:34 PM
Hesitation on acceleration skocheroni Engines & Drivetrain 16 02-07-2007 06:54 PM
